Question about Ematic EGS102 Genesis Prime XL 10" Touchscreen Android Tablet - Black
No power Won't power on
I have a samsung galaxy tab E that won’t recognize its charging adapter or cable. I ordered a new factory specific charger and am still having the same problem.
Hi unplug charger hold down POWER BUTTON FOR 30 SECONDS
KEEP HOLDING BUTTON DOWN PLUG IN CHARGER AND HOLD POWER BUTTON DOWN FOR ANOTHER 30 SECONDS.. cheers
Jan 30, 2018 | Samsung Tablets & eReaders
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
My kindle fire won;t let me turn pages or change any thing
Soft Reset:
  1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
  2. Your reboot screen should appear when you release the power switch.
  3. Give your device time to reboot for a minute or two.
  4. Turn the Kindle Fire HD back on.
kindle fire Google Search
Nov 30, 2016 | Tablets & eReaders
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Sony tablet
Option 1 (Non-destructive)
  • Press and hold the power until it powers off. This is considered a "hard reset"
  • Power the device back on.
Option 2 (Destructive)
  • Typically involves powering off the tablet. Once off tap the power button then press and hold Power + Vol Down until you get a menu
  • Us the volume buttons to navigate to "factory reset"
  • Use the power button to select it.
  • This will wipe out the tablet and reset it back to defaults.
Apr 23, 2013 | Tablets & eReaders
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
Nexus 7 16gb tablet won't power on
I would do a hard reboot. To do this you should hold down the vol up, vol down, and power buttons. This should bring you into recovery mode. Others seem to be having similar issues. Warranty?
Oct 19, 2012 | ASUS Google Nexus 7 Tablet
Tablet crashed won't do anything
coby has recently had major tablet problems,call manufacturer.send 15.00 money order.
Jul 22, 2012 | Coby kyros Tablets & eReaders
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Ematic EGS102 Genesis Prime XL 10" Touchscreen Android Tablet - Black Logo
21 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
