Question about Roku Enhanced Remote for 3
Enhanced remote will not update
Error report could not update remote
Why does the Acer Aspire has a constant pop up window that says: Werfault.exe/ with #s 0x77317d56 rerfence memory at 0x00000008, what does this window mean???
it means the file werfault.exe try to run on your PC but had an error.one option is to find the file and delete itbut I would suggest you find out what the file is back to doing it stop your computer from trying to run a file instead
Jul 14, 2014 | Acer Aspire T650 (AST650UC3601) PC Desktop
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Jul 25, 2012 | Computers & Internet
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
USB ports unusable
update your windows install original driver usb hub controller & host controller.
May 31, 2009 | Toshiba Satellite M35X-S311 Notebook
When I try to open design enhancer I get an error
This error can appear when you attempt to start 4D software. This will happen if you have installed any version 8.0 4D software, and the 4D Embroidery System software that is already installed has a later version than your 4D software.
If you have a CD (or DVD) containing 4D Embroidery System Software for version 8.1 or later, install the update for the 4D Embroidery System found in the Patch folder on the CD (or DVD).
If you have updated your 4D Embroidery System to version 8.1 or later using an update obtained with Smart Update, find the update you have already downloaded and run it again.
If you are unable to find the update, or you are not sure if you have the latest update, use Smart Update to obtain the latest update, as described in CC007.
When you run the update, you may be asked to choose between Modify, Repair and Remove. This selection appears because you have updated on a previous occasion. Choose the Repair option, and this will ensure all your 4D Embroidery System software is updated.
Mar 14, 2009 | Husqvarna Viking 1
Continuous BLUE SCREEN after sp2 install.
After you upgrade your computer to Windows XP, you might receive the following Stop error message when the computer starts: STOP: 0x0000007E (0xC0000005, 0x804E518E, 0xFC938104, 0xFC937E04)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
WUSB54GCx86.sys- Address 92D89498 base at 92D7c000, Datestamp 45c04cc9 Note The parameters and file names in this error message might vary, depending on the cause of the Stop error. The file name in the second line of the error message, WUSB54GCx86.sys, is an example of a driver file that might be causing the error.
This article discusses seven methods for resolving the problem. The first method is designed for beginning to intermediate computer users. The other six methods are designed for advanced computer users.
Because this article contains steps that involve restarting your computer, you might find it easier to follow the steps if you print this article first.
CAUSE
This issue might occur if a system thread generates an exception that the error handler does not catch. This exception can be caused by any of the following: • If this issue occurs after the first restart during Windows Setup or after Setup is complete, the computer might not have sufficient hard disk space to run Windows XP. • The computer BIOS might be incompatible with Windows XP, or it might have to be updated. • The video adapter drivers might be incompatible with Windows XP. • A device driver or a system service might be damaged. • If the issue is associated with the Win32k.sys file, it might be caused by a third-party remote control program.
Use the Windows Error Reporting tool loadTOCNode(2, 'resolution'); You can use the Windows Error Reporting tool to send information about the error to us and to obtain information about any available fix or workaround. Follow these steps to use the Windows Error Reporting Tool: 1. When the Windows Error Reporting window pops up on your computer, click Send Error Report to send the error report to us. 2. In the confirmation window that appears after you send the error report to us, click More Information. This helps you find any available fixes for the problem or information about how to work around the issue. 3. If a fix or a workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue. If you are not comfortable with advanced troubleshooting, you might want to contact Support. For information about how to contact Support, visit the following Microsoft Web site:
Method 1: Make sure that you have sufficient hard disk space loadTOCNode(3, 'resolution');First, make sure that you have sufficient hard disk space. The Stop error can be caused by insufficient hard disk space.
If you can use safe mode or the Recovery Console to start the computer, delete any unnecessary temporary files, Internet cache files, program backup files, and files that contain saved file fragments from disk scans (.chk files). You can also install Windows XP on another hard disk that has more free space.
If you cannot start the computer, go to the next method to update the computer BIOS.
Method 2: Update the computer BIOS loadTOCNode(3, 'resolution');If freeing space on your hard disk did not resolve the problem, the BIOS might have to be updated. Use the hardware and software vendor contact information articles that are listed in the "References" section to contact the computer manufacturer to obtain the most recent BIOS update.
Note When you update the BIOS, you might have to disable BIOS memory options, such as caching or shadowing, temporarily.
Method 3: Disable or update device drivers loadTOCNode(3, 'resolution');If you have updated the BIOS successfully and the problem persists, the video adapter drivers on the computer might have to be updated or disabled. Follow these steps to troubleshoot the video adapter drivers: 1. If a driver is listed by name in the Stop error message, disable or remove that driver. • If the error occurs during the startup sequence and the system partition uses the NTFS file system, you might be able to use safe mode to rename or to delete the faulty driver. • If the driver is used as part of the system startup process in safe mode, you must use the Recovery Console to start the computer. 2. If the Stop error message does not indicate a specific driver, update the video adapter drivers to the latest versions. 3. Disable or remove any drivers or services that you recently added. 4. Check the Microsoft Hardware Compatibility List (HCL) to determine whether the PCI devices in the computer are compatible with Windows XP. For information about the HCL, visit the following Microsoft Web site:http://www.microsoft.com/whdc/hcl/default.mspx
Method 4: Remove unsigned driversIf you have updated the video adapter drivers and the problem persists, or if you cannot start Windows in safe mode, the problem might be caused by a different, unsigned driver. Remove all drivers that are not digitally signed by Microsoft. For more information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
316434 (http://support.microsoft.com/kb/316434/) How to perform advanced clean-boot troubleshooting in Windows XP
Method 5: Remove all third-party drivers loadTOCNode(3, 'resolution');You might be unable to determine which third-party driver causes the error. If removing unsigned drivers does not resolve the issue, try moving all third-party driver files from the %Windir%\System32\Drivers folder to a different location. Follow these steps to move the third-party driver files: 1. Use the Recovery Console to start the computer, or start the computer from a different installation of Windows if you have performed a parallel Windows installation. 2. Create a temporary folder to hold the driver files. For example, you could create c:\DriverTemp. 3. Move all files that do not have a creation date for Windows XP of 8/13/2001 from the %Windir%\System32\Drivers folder into the temporary folder that you created in step 2.
Caution If the computer relies on third-party IDE or SCSI controller drivers for correct operation, you must identify those driver files and then leave them in the %Windir%\System32\Drivers folder. 4. Restart the computer. 5. Continue the Windows Setup program. You can add the driver files back to the computer one at a time to identify the faulty driver.
Method 6: Remove third-party remote control servicesIf you still have the problem after you use the previous methods and the Stop error message contains the Win32k.sys file name instead of a driver file name, the problem might be caused by a third-party remote control program. To remove the service, use the Recovery Console to start the computer and then delete the third-party remote control service file.
Oct 24, 2008 | Intel Motherboard
Firewall Updates (Software vs Hardware)
If the updates indicate that they correct a security flaw then they should be applied.
If the updates add features or enhance features then they are not critical and should be considered optional.
I have audited banks and the most important thing is to make sure that any problems reported by their last federal audit are addressed before the next audit. Get the bank to give you their last federal audit report and go from there.
Mar 28, 2008 | Efficient Networks 5930 ADSL Business...
Error Report
An error message referring to BRSVC01A.EXE appears after installing the printer driver on Windows® XP SP2 or Windows Server 2003.
You will need to update the program of the installed driver.
Click Here for update from brothersoft:
thanks
iqbal
Mar 27, 2008 | Computers & Internet
Roku Enhanced Remote for 3 Logo
15 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
