Question about Xerox Office Equipment & Supplies
Fuji fault codes
Fault code 092-319
Fuji tech air conditioner f8 code
This is usually be caused by the outdoor motor fault or outdoor PCB fault
Dec 20, 2016 | Heating & Cooling
Orange light continues to blink indicating a information message. Says to clean pinch rollers - I did. Reset counts both on operator utility and on the scanner. Light blinks. How do I turn it off?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 15, 2015 | Fujitsu FI-6800 Document Scanner,...
MY YBR ENGINE MANAGEMENT LIGHT FLASHES 3 SHORT FOLLOWED BY 3 FAST
That indicates fault code 33 which is a faulty ignition coil
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
Jan 08, 2015 | 2009 Yamaha yBR125
Need code of fuji electric a/c in a KT-e02 universal remote control
If you wish to get more details, check the sites linked here. It has set-up codes & set-up procedure to many popular brand remote controls. Surf the site with patience.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Oct 19, 2014 | Televison & Video
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Fuji FinePixViewer booting error.
Your operating system is probably outdated for the firmware of the device you are trying to connect. Upgrade.
Dec 21, 2012 | Fujifilm Finepix A900, A825, A820, A610...
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
Service code
all for phgotocoper kanika codes
Dec 11, 2007 | Fuji PrintPix NC-1000 Thermal Printer
175 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
