Home | Bosch | HCBG500, 5 Pc Industrial Hammer Drill Bit... | No power
Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
Problem for Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
No power
By ericleehardi on Jun 15, 2009
I have a corded Bosch hammer drill and when i squeeze the trigger, nothing happens. is there an internal fuse or another suggestion?
Solution #1
posted on Jun 15, 2009
Not Rated)
wankiewood
Rank: Master
Rating: 84%, 7 votes
Check the Cable between the plug and the switch for continuity using the ohmeter or continuity tester part of a cheap multimeter. Place one lead on each of the plug contacts in turn, and the other on the other end of that wire. If this is okay, check the switch for continuity by placing each lead of your tester on the in and out contacts and pressing the trigger. If still no joy, check the brushes. If still no joy, check the motor windings for continuity.
Was this helpful?
Yes
No
Popular Solutions for Bosch HCBG500, 5 Pc Industrial
Questions and Unsolved Problems for Bosch HCBG500, 5 Pc Industrial
Do you recommend Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set?
Answer
Answer
my wicks cordless hammer drill always in hammer mode. i can turn the dial to normal drilling mode... (More)
Answer
quando estou usando a furadeira c a ponta da broca p baixo ela faz um barulho estranho como se... (More)
Answer
My bosch hammer drill will not hammer? How can I repair the problem?
Answer
Can you tell where I can Buy one of the New Bosch 4-32 DFR Rotary Hammer Drills in Sydney, Australia... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch HCBG500, 5 Pc Industrial...:
Top Drill Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Drill Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
