Question about Relic Watches
Manual for zr77060
Battery type
Where can i get a battery
Easiest way is to take watch to a watch repair, jewely store, or big box store like Walmart. They can sell you that battery and install it for you.
To determine the battery type, you will need to refer to your manual, or you can try looking on the back of your watch (which sometimes lists the battery type.)
Apr 01, 2015 | Ohsen YI-0815-4 LCD Silicone Digital...
Can i get a battery
Apr 01, 2015 | Watches
Where can I get a battery for a Ohsen wr30m Watch?
Easiest way is to take watch to a watch repair, jewelry store, or big box store like Walmart. They can sell you that battery and install it for you.
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Where can i get casio edifice s 1087dy model watch batteries in Ghana?
As this watch is not a solar powered watch,no special batteries needed.You take them off (if you can) and go to a battery shop to buy new ones.
Otherwise you can consult your watch manual and see the right type of batteries.
Aug 09, 2013 | Casio Watches
Misplaced my instruction manual - need to reset all after battery replacement - it's been a great watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Most makers advise you to have the battery replaced professonally, so you may not find anything useful in the hand book.
It is usual to shor the battery case to the ac point on the watch using a metal object (e.g. a pair of tweezers), to reset the watch.
Jun 03, 2011 | Timex Expedition 84601 Wristwatch
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
Is a manual available for a Sonic B16 Renegade watch? What is the battery type and how to replace battery?
Remove the back, take out the two screws on either side of the CR 2016 coin battery. Replace.
Jul 05, 2010 | Gametime Seattle Sonics Coach Series Watch
What type of battery
The battery type will be in the manual that came with the watch. No manual? Open the watch and see what it is. 95% of the time Walmart will have the one you need @$5 Or, just take it there. They will do it for you.
Dec 27, 2009 | Fossil CH2332 Wrist Watch
Watch battery and manual for Skagen 271sgxd
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty!
http://www.skagen.com/service/watchWarranty.fx
p.s. the manuals are all on this site as well!! thanks!
Jul 03, 2009 | Skagen Ladies - DEMI CRYSTALS LINK WATCH...
Watches Logo
14 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
