Question about Rittenhouse Jd9-c Green Garde Spray Gun By Hudson - Jd9c With Medium Nozzle
Dripping and leaking from rear of spray gun.
Solution leaks from just above above handle on spray gun ( rear of spray gun).
Part 38528 is more than likely bent.
Posted on May 04, 2018
Campbell Hausfeld HD4200 spray gun. Will not spray plain water. no siphon effect at feeder tube. What to check?
Check for air leaks above the top of the feeder tube. If it leaks air there, then no suction. Bad gaskets often cause this.
Oct 28, 2016 | Campbell Hausfeld Air Tools & Compressors
Paint leaking out of tipof gun what can it be
The gun is dirty regaurdless of its an airless or conventional
Airless is pressurized paint driven through the mechine by the pump its hydrolic. The reasons that could be leaking are tip isn't tight enough a bad or dryed paint on the gasket seal to the tip houseing or dryed paint on the neddle valve that seals the gun before the tip or dryed paint in the rear slides for the neddle .
Conventional gun would be almost the same problems execpt the tip doen't need a tip seal ..
My advice is to take the tip off .Take the nut under it off and take the neddle valve out through the back of the gun . Clean and lub it all .
Mar 25, 2015 | Air Tools & Compressors
Water dripping onto passenger side floor from the inside passenger assist handle.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Bob
Jan 05, 2015 | 2003 Chrysler Town & Country
I have a 1989 f150 that is leaking oil from some where on top of engine. I just replaced the rear main seal and valve gaskets look good. The oil is dripping down the bell housing.
Start at the top of the engine and work your way down, intake manifold end gaskets possibly, try some leak detector spray. Looks like a powder when it dries....spray it on the area of the engine you suspect the oil is leaking from, let it dry......go drive it for a bit and recheck.....use an inspection mirror, the oil trace will show up as a dark streak when it leaks. Try NAPA. Good luck.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Mar 12, 2011 | 1989 Ford F 150
My dad has a MBC-496-DEX and it is leaking air fluid beetween the nozzle and handle... Plzzz help ty!
rebuild and replace gaskets in gun ( call or email devilbiss for ins. or take to repair station.
Feb 13, 2011 | DeVilbiss Air Tools & Compressors
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Rittenhouse Jd9-c Green Garde Spray Gun By Hudson - Jd9c With Medium Nozzle Logo
79 people viewed this question
Top Rittenhouse Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Rittenhouse Garden Expert? Answer questions, earn points and help others
