Question about Lamber Dishwashers
Wont clean dishes
Model 01 fek will not clean dishes
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
C1 streaming settings
My mobile not vedio stream please help me
Jul 20, 2011 | Nokia C101 Cell Phone
Wont get dishes clean. hace cleaned out the filters in bottom still wont also wont dry dishes
The heating element in the bottom may not be working. Are you getting steam when opening the door during running? Hope this helps!
Sep 22, 2010 | Frigidaire Dishwashers
MY MAYTAG dishWASHER suddenly will not go through both cycles so the dishes do not get clean It is an older one that has the cutting board top. Not built in. Anyone out there. I thought if I take the door...
dishwashers normally stop(thermostop)to wait for water to heat thus maybe the element is fault,try getting a good ohm reading from element,like 20 ohms,hope this helps
Jan 08, 2010 | Dishwashers
Dishwasher wont clean
are the bottom dishes clean and not the top?could be the chopper broke
Oct 21, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
You need to rinse the dishes first and then do not cover the dishwasher soap dispenser
Jan 02, 2008 | Danby 22 in. DDW396 Free-standing...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Lamber Dishwashers Experts
Are you a Lamber Dishwasher Expert? Answer questions, earn points and help others
