Question about glogster.com
My glogster wont save
After i finished my project and pressed the save button...it just keeps saying please wait your glog is being saved but nothing is happening
Trouble uploading audio, wheel keeps spinning
I f the wheel keeps spinning your WiFi (enternet) is too slow.
You can also save it first then log off and start again.
Jan 13, 2013 | glogster.com
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
I created a glog at glogster.com. It shows up on the Web but when I go to edit it, there is no content or images on the Dashboard!
I have an account and when I type glogster in the web address it won't load so I refresh and it says "Something really bad happened' Code 404. What do I do??
May 06, 2011 | glogster.com
How to make a slideshow in youtube ?
follow these simple steps to make the video and successfully upload it to youtube:
-open windows movie maker
-press 'import audio/video'
-import the song you want to use
-drag it to the time line
-press 'import pictures'
-import the pictures you want to include in the slideshow
-drag them to the time line in the order you want them to be in
(this next bit is important in getting it to work in an accepted video format)
- when you have finished and want to save it, you must press 'PUBLISH MOVIE' at the top of the screen near the middle
-then press 'PUBLISH TO THIS COMPUTER'
-name the video
-save
now it will save to your video folder and will also convert to a WMV format which is accepted by youtube,and most websites, it is also one of the most commonly used so it works easy
after the video has finished converting and saving do the following
-open youtube
-sign in
-press upload
-fill in the video info
-upload the video
now wait on the upload screen until it says 'upload successful, the video will be available from 'my videos' once it has finished processing'
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Jan 22, 2011 | YouTube Videos
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
How to save voice message for Nokia 3110c?
Once you have finished listening to the voicemessage you wait for the option to save. It normally has a voice that says" To save this message press 2" If this doesn't work, just leave it and move onto the next one. They automatically save the messages if you don't delete them
May 31, 2008 | Nokia 3110 Cellular Phone
Navman tcn 320 gps
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
Mar 28, 2008 | Navman iCN 320 GPS Receiver
Not working
Oct 30, 2007 | Navman iCN 320 GPS Receiver
Creative Muvo TxFm 256Mb mp3 player
Try holding down the button for several seconds? If you just hit it for a second, it says "Please wait", but then the "please wait" message will go away, and the song will be paused. After the song is paused for a long time, it will eventually think you forgot about it and turn off to save battery life. Just keep holding the button until it actually turns off. I think it takes 3 seconds of holding the button down.
Mar 27, 2007 | Creative Labs Nomad MuVo TX MP3 Player
glogster.com Logo
107 people viewed this question
Top glogster.com Computers & Internet Experts
David Payne
David Payne
Are you a glogster.com Computer and Internet Expert? Answer questions, earn points and help others
