Question about Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quiet cycle III that won't start
I have a whirlpool quiet cycle III that I cannot start. It does not respond to any button that is pushed on the control panel except for cancel/drain. When I push cancel/drain, the number 1 appears in the time remaining window and I hear the pump running for a short time and it shuts off.
I tried the normal/heated dry/normal/heated dry/ cancel /open and close suggestion and restart but nothing happens. No other light will light up on the panel when any button is pushed.l also tried bending down the thin metal closing latch to make a better connection and this did not help.
  • 29 Answers
Check the whirlpool web site. There is a link to see if yours is affected, click that and answer a couple of questions then if will ask for the serial number and then the model number, which are located on the inside wall of the washer. When you submit these numbers it will tell you if yours is recalled which is probably the cause of your problems as well. Since mine was doing something similar and it is one of the washers on recall for a bad motor.
Posted on Jun 15, 2009
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Whirlpool gold Quiet partner III. The Normal button of the cycle is blinking and I can't start the dish washer. What is going on?
most likely the door switch is not making contact or is faulty. Shut the door tightly and see if it makes any difference.
Please provide the full model number of the dishwasher in case you need further help.
Aug 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool Gold Quiet partner III won't wash. Dishes come out greasy.
Add Jet Dry and run a cycle with dishwasher empty with bleach and should start working good
Nov 19, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Mar 21, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
346 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
