Question about Trion Teka Sink 60 S Stainless Steel $700+ Retail
I need a cutout template for teka sink model 86555
I can,t install the sink without a template to cut tbhe countertop
    Sergeant:
  • 384 Answers
If u have the sink. Put card board down for your pattern set sink on card board and trace sink .if no sink measure sink cut to size
Posted on Jun 01, 2014
Can a defective Rohl apron front sink be pulled and reinstalled?
Generally these sinks are placed into the cabinet in a cradle and then the countertop material is set "over" them for an undermount look. To remove the sink you would need to cut the front of the cabinet and also remove the cradle to drop it down and out, the only other way would be to lift off the countertops, which may not be possible depending on seams and if tile backsplashes are already installed.
Oct 18, 2013 | Plumbing
Is it a good idea to install this sink without mounting clips
you can install it without mounting clips, as I have seen it done. usually they use clear silicone under the lip of the sink, once it hardens it will not allow water or the sink to slide. Tim
Mar 28, 2011 | International Thermocast Corp Thermocast...
I have an older kitchenaid 30-inch cooktop - Model number KGCS100S. I want to replace it and need to know the size of the existing cut-out. I can't get a measurement without a lot of extra work and...
Hello
Unfortunately, the cooktop you have is no longer in production, and even if i give you the dimensions of the cooktop, the cut - out is not a standard size, some people like to make a more spacious cut - out, where others give it a tight fit.
Best way of knowing is to unscrew the screws and lift out the top and measure the dimensions yourself.
I really hope this can be of help, please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Jun 17, 2010 | Microwave Ovens
I just want to be sure I place the sink properly into the new countertop. Are there certain distanced from the back or front I should be aware of? I have an Eljer tile-in bathroom sink, model 052-0317. 21...
The most critical dimension is the clearance between the backsplash (wall side) and the sink as you want to ensure that there is room for whatever faucet set you've selected. Typically you want to leave 4 1/2 to 5" between the rear of the sink and the backsplash for the faucet but that's not critical as long as you leave sufficient space for it. A typical bathroom countertop is 22" deep so your large sink will be close fit. Now, if the faucet mounts through holes in the sink itself you can just center it.
Apr 22, 2010 | Home
How do i install them?
First do a dry fit to make sure it fits in hole properly then put a bead of clear silicone on the countertop around the cut out edge lay sink in hloe and install the mounting clips do not overtighten mounting clips they only need to be snug clean excess silicone with a rag.I suggest installing faucet and basket strainers first on sink before installing makes job easier
Nov 11, 2009 | Neptune Ace Good Series Double Bowl Sink
Fixing a franke sink
Turn sink upside down on paper/cardboard & trace around outside. . Measure from outer edge of unit to just beyond inner edge [where the clips fit] transfer this to cutout and mark/cut on this inner line. This is not your template to cut out the worktop.
Push the clips over the inner ridge on the underside until they click into place.on small cutouts make sure the worktop grips face outwards.
place into worktop cutout - most likely there will be some more worktop to trim to fit. When fitting easily, fit the seal on the underside where the sink fits into the worktop & screw up the clips until they bite into the underside of the worktop.
Not got the seal? use silicone [clear]
Aug 31, 2009 | Home
Can not get level. countertop and sink top level.
the castng on most sinks is rarly perfect, if ever. i find they always rock to some degree, thats why you sillicone them to your level counter top, besides keeping splashed water from making it's way underneath.
Aug 16, 2009 | Home
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Trion Teka Sink  60 S Stainless Steel $700+ Retail Logo
116 people viewed this question
Top Trion Home Experts
Donni Steen
Tom Chichester
Are you a Trion Home Expert? Answer questions, earn points and help others
