Question about iPhone Apps
I cant put the commas were it has to be
Reading
Where do you put commas
not sure if this is what you are after but go to this link might help you out. Where do you put commas Google Search
Oct 26, 2017 | Office Equipment & Supplies
How to add comma in spreadsheet? thanks
To add commas to your spreadsheet you need the format the numbers. If you want your whole spreadsheet to use commas, click on the area to the left of column A and above number 1. This should highlight the whole spreadsheet. Click on the "," icon in the "number" area, and your spreadsheet will be formatted to put commas in.
Good luck,
Paul
May 06, 2016 | Casio Office Equipment & Supplies
How do I type a comma
Put your finger right below the 'K' and 'L' buttons on the keyboard. If you have 'Shift' held down, you'll get '<,' but if not, the comma you've been seeking should appear.
If not, reinstall your drivers, then turn it off and back on again.
Aug 30, 2012 | Office Equipment & Supplies
How to configure email a/c in micromax Q5 mobile
Goto Menu/Services/Email/Email Accounts/ options /New Account
1. Put ur email Address ie xxxx@xxxxxxxx.com
2. Press "Next"
3. Select "POP3"
4.Choose Data Account "AirTel PocketInternet" etc.
5.Press "Next"
6.put "pop.gmail.com" (Wihout commas) as Incoming Server
7.put "smtp.gmail.com" (Wihout commas) as Outgoing Server
8.Press "Next"
9. put "User Name" ie xxxx
10. put your password
11.Press "Next"
12.Put "Account Name" whatever u wish
13.Press "DONE"
Jun 06, 2010 | Cell Phones
In my register it reads 0,00000. How do I get rid of the comma?
I am not sure if you can prevent the comma (the thousands separator) from appearing, in general. But if you are not averse to using Scientific or Engineering notations, you will not have to put up with the commas. (As an aside I will not mind having a bank account with 4 or 5 commas in the amount.)
Hope it helps.
Jul 14, 2009 | HP 12c Calculator
500 x 16 reads 8.000,0 instead of 8,000.00
The calculator has two digit-separation marks: The dot [.] and the comma [,].
By default the decimal (radix) mark is the dot, and the comma serves as a 3-digit separator. In European countries (especially France) the radix mark is the comma and the 3-digit separator is the dot.
To switch the marks:
  1. Turn calculator OFF
  2. Press and HOLD the [.] key while pressing [ON].
Apr 26, 2009 | HP 12c Calculator
Decimal point is replaced with comma
Check to see if the calculator is in European mode where the comma is sometimes used rather than the period.
Dan
Feb 20, 2009 | HP 33s Calculator
Ti-89 titanium
the comma is close to the "(" and ")" simbols
Sep 01, 2008 | Texas Instruments TI-89 Calculator
iPhone Apps Logo
73 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
