Question about Baby Lock Eclipse Serger
Changing light bulb - Baby Lock Eclipse Serger
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
How do I change a light bulb in my Bernina 707?
I don't have a 707 but do have a 530-2 Record. Unfortunately, with some of these older machines, Bernina did not provide a very good method for accessing the light bulb. On later machines, the side cover would either be hinged or removable. If yours doesn't have this capability, the only way of changing the bulb is by reaching in with your fingertips, gripping, and turning the bulb to remove it and then installing the new bulb in the reverse manner (difficult for someone with big fingers). Sometimes it helps to use thin rubber gloves (like the surgical type), lightly moisten the finger tips to provide more "grip." There is also a sewing tool available that is somewhat like a pencil with a rubber suction at the end made specifically to help with replacing sewing machine bulbs. If you are creative, you may be able to fashion something similar.
Have you tried LED bulbs? I've installed them in all my Berninas. They provide a lot more light and do not get as hot as the regular bulbs--as well as, they supposedly last much longer! They seem expensive at the outset but if I never have to change a bulb again, so much the better!
In case you need it, here is the manual for your machine:
BERNINA Sewing Systems
Oct 17, 2017 | Bernina Sewing Machines
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
How do I change the light bulb on my Bernina 1530?
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BTW--I have older Berninas and upgraded their bulbs to LED.
Oct 03, 2016 | Bernina Sewing Machines
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
Where is the light bulb located on a Memory Craft 4000 sewing machine. Need to change light
Hi Rhonda I have a 9000 and a 500e and the light should be directly above the needle shaft.
Good luck
Jan 20, 2015 | Janome Sewing Machines
Change a light bulb in Bernina 1008 sewing machinge
If you still have original Acessories there should have been a grey or brown cone shaped rubber gripper that could be slid up on bulb to assist in turning it If not remove the side cover, then back cover to access the bulb. Some 1008's have push in bulb others screw in so be careful not to break bulb as you remove it
push in bulbs must be pushe in and rotated 45 degrees counter clockwise to remove. Of course screw in bulbs just rotated counter clockwise to remove
Aug 23, 2014 | Bernina Sewing Machines
As changing the light of my jaguar sewing machine
try these sites for a manual
sewingstyle.com
sew4less.com
homeappliance.manualsonline.com
also try youtube--changing a light bulb on a jaguar sewing machine
and bing video search--changing a light bulb on a jaguar sewing machine
Apr 01, 2012 | Sewing Machines
I have a Singer Advance 7422 Sewing machine. The light bulb went out. How do I change it and where can I find a replacement bulb?
My light went out of my Singer advance 7422. Does anyone know how to change it or where to buy the bulb? Thank you for your help.
Jun 05, 2011 | Singer 7422
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
