Home | Frigidaire | FAC107P1A Thru-Wall/Window Air Conditioner | Window unit no lon...
Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Problem for Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Window unit no longer cooling
By kath62954 on Jun 15, 2009
I moved into an apartment which had a Samsung window unit in the bedroom. After a year, it has quit cooling (the fan still works well). I also noticed I don't hear the compressor kick on and off any longer.
I asked at the manager's office and discovered that the unit was left by the previous tenants and doesn't belong to the apartment complex! I loved having this air conditioner.
Is there something short of hiring a serviceman that I might try to see if I can (or my boyfriend can) repair it?
Solution #1
posted on Jun 18, 2009
Not Rated)
drewhal
Rank: Guru
Rating: 86%, 27 votes
you could pull the front cover off and see if there is a loose wire in the control box (behind where the control knobs are). it could just be a bad thermostat. you will see a copper wire with a silverish end on it coming out of the t-stat, try holding it between your fingers for a few minutes to warm it up, turn the t-stat to coldest setting possible, turn unit on, and then see if the compressor will kick on. if neither of those things help you could try replacing the thermostat, probably not expensive from samsung if the unit isn't too old. if that doesn't help either then the compressor probably bit the dust. but if not its worth fixing! hope that helps.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FAC107P1A
Questions and Unsolved Problems for Frigidaire FAC107P1A
Do you recommend Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner?
Answer
Answer
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on... (More)
Answer
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit... (More)
Answer
we bought ours from lowes and it was the display item it came with no instructions, can you tell us... (More)
Answer
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I... (More)
Answer
where does the white and black wire from the power cord hook to under the panel? I know where the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAC107P1A...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
