Question about Wilbur Curtis GEM-12D-10: Gemini Twin Brewer
Coffee brewer started brewing on own and did not stop
Wilbur Curtis GEM-12D-10: Gemini Twin Brewer started brewing on its own and did not stop
2 Suggested Answers
  • 91 Answers
SOURCE: where can I get a control panel for a wilbur
This board is expensive around $300 .I have a Alpha 3DR brewer like new for sale $200.
Posted on Jan 31, 2011
Curtis Alpha3GT coffee volume is very erratic
Reprogram control panel. or clean fill level sensor with vinegar.
Nov 12, 2012 | Curtis ALPHA3GT Automatic Coffee Brewer
My Platinum brewer has begun brewing on it's own.
They advised me to stop using it and buy a new one. and why do you not listen to them
Nov 26, 2017 | Keurig Platinum B70 Coffee Maker
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
Keurig will start to brew..noise get louder and stops before brewing.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 27, 2011 | Keurig B60 Coffee Maker
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
The coffee maker is not making a full pot of coffee
hi..
the model may have a digital timer that is accessed using the panel swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type... To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached...
thank u
rate me!!
Aug 14, 2009 | Wilbur Curtis Alpha G3 Concourse...
MyCurtis,Alpha-111S coffee machine isover filling the coffee pots
that model may have a digital timer that is acssed using the panal swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached
Jan 04, 2009 | Wilbur Curtis Alpha G3 Concourse...
Wilbur Curtis GEM-12D-10: Gemini Twin Brewer Logo
Top Wilbur Curtis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wilbur Curtis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
