Question about Vitamix Vita Mix Maxi 4000 Commercial Mixer Blender
Spilled soup into vita- mixer maxi 400
Now unit does not power up.
My Hobart mixer HL-400 shots off undr the heavy loads
that is because you are overloading it. the 400 watt is only a medium power. I have a 800 watt stand and i do load it and it takes it.
do you have it on an extension cord?
are you using the wrong attachment?
regards
sir jdht
Apr 25, 2017 | Hobart Food Mixers
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
My bamix attachments keep falling off, tried tightning them as per instruction book to no avail.
II had the same problem but I just kept adjusting it and make sure it fits into the notch, and it works. It a bit annoying, but persevere.
Best wishes
Jan 15, 2012 | Bamix De Luxe Hand Mixer
My 20 qt. mixer has no power in speed #1.
Hi All. Since the original poster has not responded to my request for ML and spec. #'s, I'll offer a solution based on a spec.# 3943 for anyone with the same problem. This is an older model A200 with a solid aluminum gearshift lever.
Stop using the mixer!!!
The slow speed gear (1st. gear) is engaged by a "diving key". Over time this key can wear to the point of failure, or break entirely and will no longer engage. This failure only affects the first gear, allowing the second and third gears to function properly. If you can stop the mixer attachment by hand while in 1st. gear, then you have the above problem. The unit must be serviced. If the key has been sheared there is the potential for a broken piece of this key to get into the trans. grease and cause further damage to the mixer. For a Hobart Tech., this is relatively easy to repair as a minimum number of parts need to be removed in order to expose the diving key.
Call your local Hobart office to schedule a repair. If you've never done any repairs on this model, do not tackle this project by yourself. I you have some experience with this model goto the hobartservice.com website, register for free and then download the parts list. Ensure that you have the list for the 3493 spec.
If anyone has been assisted by this solution, please rate it. ricardok45
Mar 17, 2009 | Hobart A200 Stand Mixer
Oil spilled during shipping
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Emerson MW 8115SS
Remove screws, remove cover, replace 20A 125v fuse. Should work.
Nov 16, 2007 | Food Mixers
Vitamix Vita Mix Maxi 4000 Commercial Mixer Blender Logo
Top Vitamix Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Vitamix Food Mixer Expert? Answer questions, earn points and help others
