Question about U-Line 75BEV Beverage Cooler
Uline 75bev not working
Not working
Glass door has condensation outside and slightly inside. 75bev
That would be normal if the day is very humid. Any cold surface will change the water in the air to a liquid. Like steamed up glass when you shower.
Aug 20, 2016 | U-Line 1175BEV Beverage Cooler
HELLO I HAVE A ULINE WH95TP IN A BOAT WE HAVE IN FOR REPAIR AND THE ICEMAKER WONT GET COLD WAS WORKING BEFORE ANY THOUGHTS ON WHAT TO CHECK THERE ARE NO SCHAMADICS ON IT THANKS JOHN
Ice makers need refrigerant just like freezers and if it get too low it will quit working and probably burn itself out .call a refrigeration repair person and ask them to check it out .
Jul 30, 2015 | ULINE U Line Marine/rv Ice Makers Wh95tp...
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
Feb 26, 2009 | U-Line 75R Refrigerator
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Dec 23, 2008 | U-Line Icemaker
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
U-Line 75BEV Beverage Cooler Logo
21 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
