Question about Technical Pro 2000W 2-Channel Power Amplifier
Left channel blown
Buddy of mine thought he knew how connect the technical pro 2000 to the dj equip. correctly .but he didnt he turned it on the music played for a few seconds and it stopped.the room smelled like some thing was burning ,sure enough he burned the left channel.
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
"effects on" button stopt work after 1 houer!!!! need help
Most likely internal fuse for effects module has blown. look inside the mixer for the blown fuse (it'll be near the bit that's not working) and replace with a fuse of the same rating,
Mar 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Jan 18, 2009 | Technics SL-1210 Turntable
Vestax o5 pro mixer channel 2 not working
Doe you get sound in from the headphones? If so, then the issue might be the volume fader for that specific channel.
If not, then the issue might be the input connections or input pc board the connections are soldered on to.
The fader can be self replaced, although complete disassembly of your unit is required. Not a hard task, but there are alot of jumper cables, and you have to be careful when putting her back together.
If it's the latter, then I would suggest taking it to a service center for repair.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 20, 2008 | Sony PS-LX250H Turntable
Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
A DJ Pro Audio Co.
Dec 17, 2008 | Technics SL-1200MK2 Turntable
Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
A DJ Pro Audio Co.
Dec 14, 2008 | Technics SL-1200MK2 Turntable
Master channel problem
There is a master gain volume on the rear of the unit. Make sure this is not maxed out. Keep it between 1/2 to 3/4's of the ay up.
If this does not solve your problem, your going to have to give me more details. What do you mean when you say "moved off 0 peaks red on left"? Do you mean that when you lower the master volume, the left signal is still hot (red)?
- OPTiC
A DJ Pro Audio Co.
Nov 30, 2008 | Pioneer DJM-600 Silver Professional DJ...
Connection help
Nope. There are no input connections on the DZ1200. However, you can use programs like Serato, CUE, TRAKTOR, or PCDJ, and you can keep your music on your computer/hard drive, and control with the DZ1200 via specially coded CDs.
- OPTiC
DJ Pro Lab
1200s.com
Aug 16, 2008 | Technics SL-DZ1200 CD Player
Outputting high pitched sounds and master balance switch problem
Maybe the issue is not with your mixer. Maybe its with one of the units you connect to the mixer. Does this happen in all the channels?
If the service company could not duplicate the problem, then the problem might be somewhere else. Double check and replace your cables going to your amp, as well as the cables coming from your CD players and such.
- OPTiC
A DJ Pro Audio Co.
Dec 06, 2007 | Pioneer DJM-600 Silver Professional DJ...
Technical Pro 2000W 2-Channel Power Amplifier Logo
Top Technical Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Bapco
Are you a Technical Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
