Question about Magic Chef 31000 Gas Kitchen Range
How to light oven on a Roper model FGP315EW
Where is the igniter for this oven
Oven igniter
Igniter Knob replacement.
Jan 10, 2014 | Roper FGP215KQ Gas Kitchen Range
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Why won't my roper gas range (FGS337KQ) stay lit? The oven will light for 30 seconds and then shut off. Ignition is working.
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Oct 30, 2009 | Roper FGS337 Gas Kitchen Range
Have Roper LP Range model S8757. This is a self cleaning oven but takes forever. So I cleaned it myself and now oven won't light. Get F3 on display.
Your oven temperature sensor is bad and must be replaced.
It is inside the oven, a short metal piece extends into the oven. It is secured by a screw into the back wall of the oven.
Oct 12, 2009 | Roper FGP305 Gas Kitchen Range
Oven does not ignite, nogas coming out
Most likely the ignitor needs replaced. Checking it with a meter will verify. If it is OPEN then replace the ignitor. IF it SHORTED then the gas safety valve will be bad also.
Eric
Sep 14, 2009 | Ovens
The electric spark lights the gas at the spark area but the rest of the oven flame never materializes and the spark continues to click even though the initial flame is there
Make sure the thermocouple from the gas valve is in the pilot flame. If it is and you have no ignition,replace the gas valve. The clicking stops once the oven ignites.
Aug 24, 2009 | Roper FGP215KQ Gas Kitchen Range
My roper oven will not light. the starter element will glow
I assume you are saying the oven will not light but you can see the igniter glowing....if this is the case you will still need to replace the igniter, igniters need to be drawing a certain amperage before the will open the gas safety valve. in this case your igniter is glowing unevenly orange and is old - it is not pulling enough amps to open the valve. Replace it and you should be good to go.
Jun 22, 2009 | Roper Kitchen Ranges
Magic Chef 31000 Gas Kitchen Range Logo
22 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
