Question about RCA P56930BL 56" Rear Projection Television
Tv beeps the tv wont turn on and when its pluged in theres a chirping noise and when u unplug it it slowly stops.
  • robi_terry Jun 15, 2009
    i knew it was a compacitor but just dont kno which one, which one was bad on yours
  • 53 Answers
That is means one of the capacitors inside the TV is bad. You can get the capacitor replaced, but it normally takes an expensive technician. We had the exact same problem with one of our tvs and the repair was 230$. If the tv is still under warranty have the manufacturer fix it. If not hire a tv repair technician. I do not reccomend fixing it yourself because it can be dangerous even fatal.
Posted on Jun 15, 2009
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
A/C chirping noise Camry 1998
If there is chirping noise then some object in the blower motor or the blower is making noise due the frictions b/w the walls of the blower motor unit ,you need to check the blower motor .....
Good luck...
Jan 19, 2009 | 1998 Toyota Camry
Beeping noise when I turn on my TV
www.TvRepairKits.com just added a kit for the "chirping set" problem.
Hope this helps,
Dec 03, 2008 | Philips 46PP9302 46" Rear Projection...
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Jul 16, 2007 | Philips 60PP9352 60" Rear Projection...
Television won't turn on
The beeping sound is the power supply trying to start up. That means there is a short somewhere inside the set. On these TV sets most of the time this trouble is in the horizontal sweep circuit. Sorry but the only way to reset a TV set like this is to unplug it for several hours. But in this case I doubt very much it will work. If you have no solid state repair experience then please call in a certified tech to assist you in this repair. Let me know how you made out. Good Luck
Jun 28, 2007 | RCA F27681GY 27" TV
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Televison & Video Logo
165 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
