Question about Samsung RF263AEWP 25.8 cu. ft. French-Door Refrigerator with 5 Glass Shelves, Spill Proof, Twin Cooling System, CoolSelect Pantry and Power Freeze/Cool Options: White
Twin cooling system won't shut off
Tried unplugging it and it still does it
Www frigidaire com MY FFHS2313LM6 the temperature is sky high and won't cool down.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Aug 25, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
Electrician was here yesterday and shut fuze temporarily. It's back on, but system is not cooling. where is the reset button? Model: MSB2354AR
Hi and welcome to FixYa. I am Kelly,
There is no reset button. There is a thermal overload on the compressor called a KliXon and that is what should be cycling about every 5 - 8 minutes if the compresor did not start.
When there is a temporary loss of power 10 minutes or less there is a good possibility that the internal coolant pressures are way to high for the compressor to start. Unplug the unit for 15 - 20 minutes and plug it back in FIRST. (longer is better) This will give the coolant system time to equalize so the compressor can start. If after trying the unplug / wait / re-pulg routine it still does ot start or cool just repsond here and I will gladly help you.
Thanks for choosing FixYa,
Kelly
Oct 22, 2010 | Maytag Freezers
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
The freezer works fine, but if you unplug it, it won't start back up, you have to let it sit unpluged for about 30 minutes to an hour before it will come back on. Its like it needs to cool off, it does get...
The high side and low side of the refrigerant system , have to equalize , before the compressor can start . If you unplug , then plug back in , the high side has a lot more pressure , therefore the compressor will not start and the overload will cut the compressor off . When overload cools slightly , compressor will try to start again . If pressures not equalized , overload will cut compressor off again . As this happens , the compressor will get hotter and hotter . Eventually , pressure will equalize and compressor will continue to run . Very bad on compressor and components .
Aug 06, 2009 | Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Kenmore freezer is not cooling
Listen for some type of noise from the back lower part of the freezer. This could indicate a problem with the compressor. It is not a fast fix problem. Get your frozen foods to a cold temperature. If the compressor is running and you are not getting the cooling your system could have lost its refrigerant charge. If the compressor is cool and not running check the temperature control. It may have failed. Unplug the power to the freezer and remove the temperature control. Jumper the two main wires that attach to the temperature control and insulate them with electrical tape. Plug the freezer back in and the compressor should start and cool. If this makes it run replace the thermostat.
Jul 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Samsung RF263AEWP 25.8 cu. ft. French-Door Refrigerator with 5 Glass Shelves, Spill Proof, Twin Cooling System, CoolSelect Pantry and Power Freeze/Cool Options: White Logo
59 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
