Question about Miele WT 2780 Front Load Washer
Wt2780 fault 55
What is the fault
How to fix Vertical bar on Samsung Electronics 55 UN55ES7100F?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 16, 2016 | Samsung Electronics Samsung 55" UN55ES7100...
What does codes 54 and 55 mean on my 2001 freightliner columbia 60 series detroit
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
May 19, 2015 | Cars & Trucks
How to fix a fuzzy screen on an 55" sony lcd tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 29, 2015 | Sony KDF-E55A20 55 in. LCD Television
What is fault 55
Water Temperature. 55 is the temp of the water. There is no fault code 55. By displaying this temperature, it's telling you that the washer needs warm or hot water. You could have a faulty water valve. See if it fills on hot. If it is slow fill on hot, it would also display 55.
Aug 02, 2014 | Miele Washing Machines
Fault 23-55
A 2000 model vehicle should have 3 or 4 digit codes such as P0023.
Is that what you are looking at ?
Jan 23, 2014 | 2000 Dodge Grand Caravan
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
My 95 eclipse is throwing codes 12, 31, 43, and 55 what do these codes mean?
12-cam shaft position Timing over retarded
31- HO2S heater Control Circuit Low (Needs a new O2 Sensor is what this is telling you)
43- HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
55- HO2S Heater Resistance (Bank 1, Sensor 3)
All of those assume they are supposed to be preceded by a P00
If you are getting ODBI codes these are teh definitions you are looking for:
Code 12 Air flow sensor fault
Code 31 Knock sensor fault
Code 43 EGR fault
Code 55 AV valve position sensor
These may make more sense with that year model.
Jul 22, 2011 | 1995 Mitsubishi Eclipse
I have 4 codes, 12, 32, 41, 55 If you can help I do thank you.
12 memory to controller has been cleared within 50-100 engine starts
This is not a fault code.
32 egr control solenoid circuit, open or short detected
41 charging system circuit not responding to control signal
55 end of message (test complete)
Jan 26, 2011 | 1995 Dodge Caravan
Need to know obd code for 96 jeep cherokee it gives me a 12 55 and 56
12 just means the battery was disconnected within the last 50 start attempts from what I can find there are 2 types of codes for jeeps , system faults and input faults ,, the only 55, 56 I could locate were 55 = Right temperature door travel too small
56 = Right temperature door travel too large I have no idea what that means,, maybe someone whos better at jeeps could help you, sorry
Aug 03, 2010 | Jeep Cherokee Cars & Trucks
Philips 55 inch projection tv
hi it sounds like it may be tripping(not taking drugs)were the protrection curcuit detects a fault eg excessive current.and goes into shutdown mode(protection mode)and makes several atemts to switch on and will continue tripping untill the fault clears.in order to norrow the fault down one would isolate differnt parts of the curcuit utill trhe tripping stops you then know the conponent/panel area were the fault lies or it can be a dry joint (needs soldering hope it helps and tell me your knowoldge
May 28, 2008 | Philips 55PW9363 55" Rear Projection...
Miele WT 2780 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
