Question about Klipsch Igroove Sxt Ipod Speaker
Reset volume on klipsch sxt
Volume stuck on high
Boston Acoustics Solo volume knob stopped working altogether. Turning it either way does nothing, no volume number appears. Soft reset doesn't fix it. Any thoughts?
I don't know if you will see this or not, your post was 2 years ago. I have the same problem. My volume is stuck at 24. I have tried soft-reset........among other things. One thread says to turn volume down to 00 then press for 10 seconds. I have no control over the volume, so, yeah, thanks for that fix. I found that I could get the volume down by unplugging it,plugging it back in and sometimes the volume would pop up and I could turn it down one notch. I did it till I got to 00.............thought AHA! My problem is solved! No such luck. When I press the volume at 00 and try to hold it for 10 seconds, after 3-5 seconds it just pops back to the station frequency. I also thought that if I could get into the guts and spray the volume control with tuner-cleaner, it might help. No go.......after taking off the cover, I found a bunch of REALLY delicate looking electrical tapes and wires..........I was scared I would destroy something in an attempt to reach the volume control. I hate to trash this radio, the sound is awesome...............great design on the speaker, NASTY design on the controls. I'd be VERY interested to know if anyone, anywhere, has found a fix for this. I think maybe my next step will be hitting it with a hammer.
Aug 29, 2016 | Boston Acoustics Audio Players & Recorders
My volume is stuck on high. How do I fix this?
Open the Control Panel, Sound, adjust volume, OR Click on the Sound Icon in the Tray Notification Area, adjust sound. OR reboot the machine.
Jan 07, 2013 | Acer Aspire 7250-bz600 Laptop
Klipsch 2.0 volume
G'day mate not much info to go on so ill start with compter spaeker option in settings then to computer volume ( make sure mute is no on its in a little box below each 'slider' ) then check if they work on another machine ,hope this helps
Mar 29, 2010 | Audio Players & Recorders
Volume stuck in high position
Make sure that the volume + button on the front is not sticking. If it is spray a little WD40 on it and free it. Then you should have control over the volume.
Apr 05, 2009 | RCA F32648 32" TV
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Go in control panel -> sound and activate icon or adjust volume there.
Dec 15, 2008 | Microsoft Windows Vista Home Premium with...
Klipsch Igroove Sxt Ipod Speaker Logo
66 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
