4420l pcu unit
Its prompting 'time to replace pcu"
How to clear functions
Open left printer cover. Open PCU cover. Pull Magenta, Yellow and Cyan PCU units and check which one has blocked!!! Probably you will need to replace color PCU (type 145). Good luck
Sep 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Richo Printer many white lines on black print out
  1. PCU needs R/R
  2. You should replace the PCU if prints show any of the following symptoms.
    • Colors are missing, faint, or partially blurred.
    • Toner smears appear.
    • White or color rivers appear.
    • White or colored streaks appear.
  3. Important: Switch off the device and disconnect it at the mains.
  4. Open the right side cover.
  5. Pull the green levers as shown to release the inner cover.
  6. Lift the inner cover upwards.
  7. Squeeze the green lever on the black PCU.
  8. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
  9. Place the new PCU on a flat surface.
  10. Peel off the tape from around the new PCU.
  11. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
  12. Rest the new PCU in the device as shown.
  1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
  2. Lower the inner cover.
  3. Push the two green levers as shown to secure the cover.
  4. Close the side cover.
  5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
  6. Please remember to rate all users who assist you for free :)
Jul 30, 2008 | Ricoh Aficio CL3500N Laser Printer
PCU Replacement
You are more right than you know, the reason for the kit is for the reasons you said. When you change the kit all 3 colors are new and thereby not 3 service calls and 1 upset customer.
The kit is far cheaper and keep any "good PCUs" in the original package.
The black PCU is the most important one. Buying the different maint. kits saves $$$ as opposed to peicemeal.
You can put one color PCU in at a time if you wish.
-Carl, please let me know if this helps.
Apr 28, 2008 | Ricoh Aficio CL7100 Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
15 people viewed this question
k24674
