Question about Sony Vaio S Series Vpcse190x Laptop/notebook W/ Bonus
Battery life battery did not last over a year
I have a Gucci watch which cost £630.00 and the battery lasted 17 months, is that the usual life span for a battery
it can be--their is no definite life span of a battery because everything has a different draw of power a simple watch can last years while more complex such as date/stop watch /backlight etc will draw and kill battery quicker
Jul 19, 2016 | Gucci Watches
How long (time life) a car battery will last?
A battery's life expectancy is very difficult to predict as there are so many factors involved. Some batteries are of a better design than others (spiral wound absorbed glass mat AGM for example) which gives them a longer life, other factors like vibration, and temperature effect life as well. Probably the most significant factor would be the over-all health of the charging system. Is the voltage regulator working correctly? Is the alternator the correct size for the electrical load? These factors, and others make it difficult to predict battery life. I had the same battery in my diesel tractor for 15 years until it went bad, the next battery I installed lasted only two, the third one is still going strong at 5. Sorry I can't answer your question better than that.
Oct 04, 2014 | 2010 Ford Mustang
How long does a battery last in a vehicle
This depends upon the quality of the car battery, and how you take care of it. If it is in a car and the car is driven daily, you should expect the battery will last 5-7 years.
If the car is not driven for extended periods of time, a battery tender should be placed on the battery, and failure to do this can ruin a battery. If it is a boat battery, during the off season the battery should be removed from the boat and a battery tender put on the battery.
If your battery has removeable caps on the top, make sure the battery is filled to the interal ring with distilled water. It is especially important to do this before charging a dead battery.
Do not store batteries directly on cement (place a piece of 2x4 under it). I know why, but batteries stored directly on the cement seem to die much faster and have a shorter overall life.
May 13, 2014 | Cars & Trucks
We at CAAP Davao Philippines have a MGE Galaxy 3000 10KVa UPS with serial no. 13299-4. It was installed last 2003. We had three times replaced its batteries over the period of years, the latest was 2008....
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
Apr 01, 2011 | MGE Galaxy 3000 UPS System
I have a string of 20 batteries on an MGE Galaxy 3000. 3 of the cells tested bad on the last PM. The batteries are 3.5 years old and operate within the temperature limits suggested by the manufacturer....
It depends on the manufacturing battery life time. Generally they are 3 to 5 years or 5 to 7 years or 8-10 years. Nevertheless due to high cost of batteries most client opt for use 3 to 5 year life time. A simple internet search will give you the specification and from there you can decide what to do. If it is 3 to 5 years life time it is advisable to change the whole set. Otherwise you can replace the 3 batteries as a temporary solution. However it is most likely that after 3 to 6 months you will have some other bad cells.
Jan 19, 2011 | MGE Galaxy 3000 UPS System
What is the battery life expectancy for the 2006 Buick Lucerne?
Battery life is a very complicated issue, there are TONS of factors. High temperature kills batteries, if the fluid goes low, that kills batteries. If you forget and leave lights on, and the battery goes totally dead, (totally dead, zippo, not anything) that kills batteries.
Alternator diodes that fail kills batteries. So 4 to 8 years is typical life IN ABSENCE of the above types of issues. My favorite battery is Interstate. They just work really well. Costco has great battery prices, bumpy for service... Really Dislike Sears die easy.
Oct 19, 2010 | 2006 Buick Lucerne
What is a typical car battery life? Is 5 years too much to expect?
hi, a typical car battery can last up to 2 to 3 years, depends on the use. well i guess five years is too much to expect
Feb 19, 2010 | 2004 Mitsubishi Galant
How long should a crv3 battery last?
I use crv3 batteries in my Pentax istD. Believe it or not, they last over a year! Keep in mind that the simple act of testing the voltage of a crv3 will shorten its life. Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Sometimes, an invisible film on the contacts forms and gives a false reading of battery life.
Dec 08, 2009 | Pentax Optio S60 Digital Camera
I don't have a problem just a question.
The lifetime of the phone is probably unimportant. That is, the phone will last many many years if you take care of it (like most electronic devices). What is important is how long will the battery last under normal circumstances before you need to replace it. I would say that with regular use, you should expect more than one year, to almost two years of use before the battery starts to not hold a charge and will require replacement.
Jun 06, 2008 | Motorola Mobility RAZR V3
Sony Vaio S Series Vpcse190x Laptop/notebook W/ Bonus Logo
16 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
