Question about Escort Passport 9500ix Radar-Laser Detector Black 9500IX
Turns on but no sound
When I turn it on, there is no sound when it does it's checks.
On my lanos 1999 model,as soon as i turn my indicator on to turn a corner, it turns off and i then get a flickering indicator sound? i have checked, it is just the sound. What could cause this?
I would check the flasher can/cube unit, usually under dash, as it is responsible for both the actual flashing and the clicking sound.
Feb 22, 2017 | 1999 Daewoo Lanos
Stopped running
do you hear the starter turning the engine over?
If so does it sound like it is turning over faster than normal?
Have you checked the timing belt?
Have you checked for fuel pressure?
Have you checked for spark?
If you can not hear the starting turning the engine over....
1. have you checked your oil lately?
2. have you tried turning the engine over by hand?
3. Have you checked to see if there is power to the starter?
Apr 20, 2014 | 2001 Chrysler PT Cruiser
Haier digital t v no sound, no picture
Check and replace its main power regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 07, 2014 | Televison & Video
2001 ford windstar turn over wont star
CHECK FOR CODES FIRST SOUNDS LIKE CRANK OR CAM SHAFT SENSOR
Mar 23, 2013 | 2001 Ford Windstar
Have a samsung lcd 46"....turns on fine and picture looks good but no sound. I have checked the mute and also have checked that sound is turned on from the menu. Also checked to make sure no head phon
the main board will need replacement. Audio signal are produced on the main board so replacing the main board should solve the issue. You can get replacement main boards from www.tvcircuitboards.com
Dec 10, 2012 | Samsung LN46A530 46 in. LCD HDTV
No sound system
Check in the Device Manager to make sure none of the audio sound drivers have a problem.
Check and make sure you have the volume turned up and not muted. There are keys on the keyboard that will turn the volume up or down and will also mute the sound.
If you have the megaphone at the bottom right by the time, double click on it and make sure the volume is turned up and not muted.
Click Start/Control Panel and check the Audio Sound properties
Click Start/Programs/Accessories/Entertainment and check the Audio Sound Properties.
Apr 07, 2012 | Sony Computers & Internet
Steering wheel makes "rubbing" sound when I turn it
check the drive belt tension and condition,system may have air in it, check fluid level check line for signs of leaking, also there may be some internal wear in pump
Sep 16, 2009 | 2006 Hyundai Accent
Tercel 1997 direction problems
Could be a worn wheel bearing causing the brake rotor to rub the brake pads. or could be rust on the rotors and are touching the pads when you turn. let me know if that helped.
Apr 30, 2009 | 1995 Toyota Tercel
61 inch Ultravision Digital tv,no sound when I turn it on
check for defective IC401 audio amp
also check d409 d410 d414 d413 for short
and check electroletic caps in audio amp
Jan 14, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
No sound on the laptop
If you have windows XP check : control panel / Sound speech and audio devices / Sound and audio devices. Then check that the volume cursor can be moved and that the device is not muted. If this doesnt work remove the sound card from device manager, and install it back using drivers from your recovery disk or download them from Toshiba website.
Hope it helps
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Escort Passport 9500ix Radar-Laser Detector Black 9500IX Logo
Top Escort Radar Vehicle Parts & Accessories Experts
Arnie Burke
Arnie Burke
boman11
boman11
Bill Boyd
Are you an Escort Radar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
