Question about RCA RT2770 Theater System
I turn on the system it says welcome then turns off by its self, any ideas?
I can't get the system to stay on, and the trouble shooting steps in the manual are not helpful. Anyone have any issues with this?
My timer on my washier/dryer combo won't work
Go to the self help section of repairclinic.com Enter you model number for specific trouble shooting advice on you appliance.
May 14, 2015 | Washing Machines
Why won't my projector stay lite?
I'll assume you mean "stay on"
Most projectors will stay on as long as a video source is playing through them. If your projector is turning off on it's own, please check the menu options and see if your projector has "ECO" or "Power saving" features turned on.
If not or if the problem continues after turning them off, you may have a faulty projector or part.
The next step would be to contact the manufacturers support for assistance in trouble shooting the proper part to replace.
Nov 23, 2014 | Office Equipment & Supplies
Fault finding
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
    1.Turn the blower fan OFF.
    2.Press and hold the recirculation control switch and the rear window defogger switch down.
    3.Turn the ignition switch ON (ll).
    4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
    If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
    If the system is ok, the recirculation indicator stays off.
Aug 19, 2013 | Honda Civic Cars & Trucks
Sony 60" wega tv it just turned it self off when i
it's telling you to replace the projection lamp, it has burned out,
Feb 28, 2013 | Televison & Video
My dynes 40" Dx-L40-10A doesn't turn on. I hear a click but the light will stay red and nothing appears on tv. Occasionally, if i unplug the tv for a few hours i can get it to turn on.
just let me know first if you will be the one to the repair since it needs a proper trouble shooting. a voltage checking and a component parts checking. the cause of the this kind of trouble is either a power supply board failure or a bad component in the main board. so isolate the main cause you will need to have trouble shooting and right device and tools.
Nov 07, 2012 | Televison & Video
Park avenue runs but cuts off
if its not throwing a trouble code i think you best bet would be to look for a bad connection or drain on the system with a voltmeter. you can purchase a service manual such as a chilton or haynes and it will have all the trouble shooting steps outlined you need to track the issue down.
Apr 12, 2012 | 1998 Buick Park Avenue
Lc-32d62u
Check its main digital processing board. It has the fault. May need replacement.
Mar 09, 2012 | LG 42LB5D 42 in. LCD Television
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
How do you trouble shooot the dsi?
What do you mean trouble shoot?. What specific problem? Well, this link (http://www.nintendo.com/consumer/systems/dsi/en_na/index.jsp#ds_logo) will give you steps to troubleshoot most common issues that you encounter using DSI
Sep 06, 2011 | Nintendo DSi Black Console
RCA RT2770 Theater System Logo
37 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
