Ntron tens unit
Want to order new electrodes and piggyback cables for ntron 2500
2 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: Where can you order parts for Fisher Paykel GC36WAC Cooktop?
These people can get anything you need for Fisher-Paykel:
http://www.fisherpaykelparts.net
If you don't see it, ask them. They can get it.
Posted on Jan 29, 2009
I have a fujitsu air con which is flashing 3 times on the timer. It runs for 10 seconds and then shuts down and then flashes 3 times. Model is a AOTR09LCC
Serial signal (reverse) error, during operation.
Try turning power off at isolator for ten minutes and then switch back on. If error code persists, you will probably need a new controller PCB in the outdoor unit.
When the indoor unit does not receive the signal for 10 consecutive seconds during the operation >Permanent stop after 30 seconds.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor
unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Feb 19, 2015 | Fujitsu Heating & Cooling
Will disabling net bios, speed up my network, wile playing Xbox 360 muilti player games speed up my network so that I do not lag and have packet loss?
No, Netbios is essential for your network component to run, without it you would not be able to play anything over the net. In order to reduce lag and or packet loss, you should increase your bandwitdh, cable integrity, and make sure that no one else is piggybacking on your connection.
Oct 13, 2013 | Computers & Internet
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
Sometimes the ignition wont engage
There is a good probability that the starter solenoid is starting to go bad, or has poor contacts. This unit is usually located piggyback on top of the starter, and the starter doesn't have to be dismounted for replacement.Before replacing ( it is inexpensive too), check that the cables leading to it are not corroded or loose, usually just 2 cables.
Jun 16, 2011 | 2000 Buick LeSabre
How many quarts of transmission fluid does a 2500 take?
It usually takes five quarts of transmission fluid if your replacing the filter. If the transmission is completely empty, such as a new unit, it takes about ten.
Mar 02, 2011 | 2003 GMC Sierra
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
Will not pump until I move or shake float
Depending on the make and model you can replace the float, bypass it with a piggyback cord assembly or replace the pump. If you care to post the brand and model I could try and answer if parts are available or recommend a piggyback unit.
Dec 16, 2009 | Plumbing
Jan 28, 2009 | Fisher and Paykel GC36 Gas Cooktop
Presario 2500 hp
just google Compaq Presario NX9010 replacement DC Jack
Jan 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
