Question about Kenmore Black 30" Quick Touch Microwave Microhood Combination Oven 721.80033700
Replace fuse in microwave
Microwave will not heat
How do i replace a fuse on sunbeam microwave
If it does not heat, the magnetron tube died. Not worth repairing unless under warranty. Generally the only fuse is a main fuse. If it blew, the entire microwave would be dead.
Feb 04, 2013 | Sunbeam 900-watt Digital Microwave Oven...
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave not heating food
There is a fuse or fusable link inline to the brain of the microwave.
This fuse is inside the actual microwave cover. Remove the cover and follow the electical line from the plug forward and you should see the fuse. Replacement fuses can be bought at an appliance parts house.
Dave
Jan 21, 2010 | Microwave Ovens
Microwave Spacesaver #JUM 2050BH001not heating
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))...
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave want heat any longer. Everthing else is
Jul 31, 2009 | Microwave Ovens
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
Microwave runs but does not blow heat
(((The fuse is located inside the unit along side the magnetron)))....
Oct 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Black 30" Quick Touch Microwave Microhood Combination Oven 721.80033700 Logo
59 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
