I was logging on to yahoo with an I pad that I missed handled and dropped so I accidentally could not get my entire password in , So now I am having a problem putting my correct password in. The syste
I can not log onto yahoo. since does not recognize my true password.
    Novelist:
  • 110 Answers
Go to Settings>Safari>Passwords and Autofill>Saved Passwords>
Tap the log in that you want to delete and then Tap the Edit button
That should be it.
Posted on Apr 01, 2014
frcs68
  • 1605 Answers
SOURCE: I have deleted svchost.exe accidently
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Posted on Dec 02, 2008
  • 66 Answers
SOURCE: Internet Explorer freezes when I log onto RTE TV (Ire).
Sir/ Madam -
Please try to use any other browser like firfox or Chrome and see if you are able to stream video. If yes there might be a proble with Internet Explore setting .
Try below steps to fix it --
Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK
Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
Reset Internet Explorer 7 settings loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
Posted on Mar 25, 2009
LucyLili
  • 27 Answers
SOURCE: i've forgotten my password to log onto windows on
As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type Administrator (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from Control Panel - User Accounts.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password Recovery Tool software:
for example:Windows Password Recovery It is easy and convenient to use.
Posted on Oct 15, 2009
  • 12 Answers
SOURCE: getting a blue screen stop error, but cant log
Please try to start from the beginning and reformat the hard drive by shutting down the system with the cd drawer open. Then insert the windows disk and turn on the pc then the drawer closes and when it tells you boot from cd press enter. Then windows will load. It will give you a couple of options. Always choose format partition. Then you should not have any problems. Unless your hard drive is bad.
Posted on Dec 15, 2009
injkiran
  • 249 Answers
SOURCE: i cannot log on. i type in my password which is
Hi! with respect to your words, we can clear two concepts those are, you can't login since "user profile failed" and you are no more since "user profile cannot be loaded", so we need to think about new account. please consider to enter the system in general way and later try to have new account with out error and have fine
Posted on Dec 18, 2009
Testimonial: "not solved completely but very helpful."
I have new I Pad & put Yahoo e-male on it with new password. I need to change my password on my Laptop to have the same as my I-pad
No problem... Barbara Bryant,
As soon as your older device trys (and fails) to log in... it will automatically ask you to INPUT the "CORRECT" password
and you are done!
Hope that helped
iPad
Yahoo login
Dec 17, 2016 | Computers & Internet
I accidentally cleared my yahoo account how can I get it back
Hello you can't clear your account unless u delete it with yahoo support.Go to www.yahoo.com and try logging back in or try logging in and click forgot password and reset it or call yahoo cust. support.
Yahoo Support Number 1 800 675 8136 Yahoo Phone Technical Support
Sep 25, 2015 | Yahoo Computers & Internet
I missing passward and otenetive emils
Not being able to access your Yahoo! account is frustrating.
If someone has broken into your account and changed your password, or if you have forgot your password, you may be temporarily unable to access your Yahoo! account.
Fortunately, Yahoo! offers a solid password recovery process that allows you to retrieve your password and log in to your account within a few minutes.
Visit your Yahoo! log in page.
Beneath the sign in box, click "I Can't Access My Account."
Select "I Forgot My Password" and click "Next."
Type your Yahoo ID and complete the "Captcha" code.
Click "Next." If you cannot read the puzzle, click "Can't Read Code."
A new code will be automatically generated.
Choose the option to verify your identity.
If you signed up for Yahoo! cellular-password recovery, you'll see an option to receive a text message.
Click "Next" to have the text message sent.
Use the temporary password to log in to your Yahoo! account; then change your password immediately.
Answer your secret question if you are not signed up for Yahoo cellular-password recovery.
Click "Next."
Depending on your preferences, you may also have to select your date of birth and zip code.
After answering the question, you'll be able to create a new password and access your Yahoo! account.
If this fails to get any results
If the Yahoo! account password or ID retrieval methods don't work, you may want to create a new Yahoo! account.
This is done by following the "Sign Up" link at the top of the Yahoo! homepage, next to the "Sign In" link mentioned earlier.
If you choose to create a new account, be sure to remember the alternate email and cellular number you provide in case you find yourself in a similar situation down the road.
http://www.google.com/url?sa=t&rct=j&q=https%20edit%20yahoo%20forgotroot&source=web&cd=1&cad=rja&ved=0CCsQFjAA&url=https%3A%2F%2Fedit.europe.yahoo.com%2Fforgotroot&ei=OHcAUu_hOIWjkwWcyIGYCA&usg=AFQjCNHx9c7BPqXjKCOsKJqoeQpslHi1YQ&bvm=bv.50310824,d.
Mar 04, 2014 | Computers & Internet
Change my yahoo password
Sign into your Yahoo! email account.
Click on your Yahoo! name at the top of the webpage to access drop-down options.
Select the "Profile" option.
Your account page will open.
Place your cursor over "Account Info" in the toolbar.
Options will again drop down.
Click "Change Password."
Type in your current Yahoo! email password in the first text box.
Enter your new Yahoo! password in the lower two text boxes.
Click "Save."
Your Yahoo! password is now changed.
or
Contact Yahoo by email.
For this, you will be required to log in.
Yahoo Help
http://help.yahoo.com/l/us/yahoo/helpcentral/
Yahoo company adress
http://pressroom.yahoo.net/pr/ycorp/company-address.aspx
Nov 13, 2013 | Computers & Internet
I change my yahoo mail password and my yahoo email on i pad ask me to go to 'setting' to update my password. But I don't know how to do it.
when you have opened up your yahoo mail, go down you ID as it shows (e.g. Hi Jolly) on its end there is a drop arrow, click it, it will bring a down menu - follow it to "account info" and click it. It will again ask you to log in and when you do it; automatically your account info will come and you adjust and save it accordingly.
Aug 30, 2011 | Yahoo Mail
I delete most of ma yahoo mails @ last week & mistakenly some important mails too.so how can I get them back.
When you delete a contact, the information is moved to Deleted Contacts. This gives you an opportunity to change your mind and restore information back to your contact list. Keep in mind that the deleted information remains in Deleted Contacts for up to a month, and can be permanently removed at any time. Usually Found in the Contacts Tab of your Yahoo Mail under View All Contact There you can see all the contacts that you'd deleted.
But if you permanently delete your contact, you can't get them back, unless if there's a backup of your contact.
May 18, 2011 | Yahoo Mail
I cant log in to my yahoo mail account. I'm not sure the reason either its been compromised or password changed
Hello there!
You may change your password by following these easy steps:
To change your password:
  1. From the Yahoo! Home page, click on your user name in the upper right.(You will need to be signed in already)
  2. From the drop down select Account Info
  3. You will be asked to sign in again to enter your Account Info page.
  4. Click Change your password
  5. You will be taken to a page that will look like the one below.
  6. Enter your current password.
  7. Enter and confirm your new password.
  8. Click Save. You will see a confirmation page when you have successfully changed your password.
  9. Click Continue.
Your Yahoo! password always applies to your entire Yahoo! account. This means that it is valid not only for Yahoo! Mail but also for Yahoo!'s other personalized services like :
  • Yahoo! Messenger
  • Yahoo! Chat
  • My Yahoo!
  • Yahoo! Finance
Note: If you are having difficulty logging into your account or believe your account may have been compromised please request a new password
Regards,
fossildude
Mar 23, 2011 | Yahoo Mail
My friend forgot her email password and the security question too. she remember the 1st security question but the 2nd is not.please help us.
Hello there!
Please follow these easy steps:
  9. Click Continue.
  • Yahoo! Messenger
  • Yahoo! Chat
  • My Yahoo!
  • Yahoo! Finance
Regards,
fossildude
Mar 20, 2011 | Yahoo Mail
I wanna change password
You can change the password for your entire Yahoo account, which includes Yahoo Mail.
You will need to log in to your Yahoo account, and then change the account settings. For step-by-step instructions, see this help page from Yahoo:
http://help.yahoo.com/l/us/yahoo/mail/classic/account/account-03.html
Feb 18, 2011 | Yahoo Mail
Icant open my email when i go to forget password page there tell me your password cant be reset online (please help me to open my email )
  9. Click Continue.
  • Yahoo! Messenger
  • Yahoo! Chat
  • My Yahoo!
  • Yahoo! Finance
Note: If you are having difficulty logging into your account or believe your account may have been compromised please request a new password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Yahoo Mail
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
