Question about Mitsubishi HC3800 1080p Home Theater DLP Projector Projector
The Temperature light comes on after replacing bulb.
After replacing bulb the temperature light comes on after about 20 minutes.
I am experiencing the exact same problem. hope someone comes on worn a solution. projector worked fine before replacement - all fans have been cleaned and are working properly. ..
Posted on Jun 09, 2014
2004 speedometer instrument cluster lights
If any lights come on the dash that can be adjusted by the dimmer switch then it may not be the fuse. and replacing would be the next option.
Feb 17, 2017 | Cars & Trucks
My temperature gauge don't move and my check engine light does not come on
Bulb is possibly out behind the instrument cluster for the check engine light. As far as the temperature guage not working it sounds like your temperature sending unit is not working if it doesn't move at all. If your thermostat is stuck open it would come up some. If not your temperature sending unit is bad.
May 31, 2015 | 2002 Ford Explorer
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Temperature gauge goes from zero to overheat
Your coolant temperature sensor is bad,it's screwed into engine by thermostat housing,easy to remove,just disconnect electrical connector and get wrench and remove.
Jan 20, 2013 | Cars & Trucks
The heater light light comes on when first low circulation cycle is pressed but turn off when you press again but only for 20 minutes
It is supposed to. When the heater reaches the temperature you set, it goes off and the indicator light goes off too telling you the heater is off. Soon the temperature drops again and the heater, and the indicator light, comes back on.----This is the working procedure.------ The pressure switch, float switch all needs to be inspected.------- Also what is the exact brand and model of your heater.This will help, to get exact cause of the problem. --------- Keep updated, thanks.Helpmech.
Aug 13, 2011 | Pool & Spa
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
Projector shuts down after a couple of minutes with lamp and temp lights flashin, is this a fan poblem and can i replace the fan?
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
May 30, 2010 | Acer PH110 Multimedia Projector
I have a 1999 Toyota Camry (4 Cyl). It comes up
The sensor for the fans is in the rad at the bottom. T-stat may be bad or the rad may be clogged. Cooling system needs attention.
Jun 15, 2009 | 1999 Toyota Camry
Mitsubishi HC3800 1080p Home Theater DLP Projector Projector Logo
171 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
