Question about Skate Out Loud Laser Hard Nose Skate Plate Complete
I changed oil in my 2001 cadilac deville with 20w 50 oil but is making a loud sound since then at staring time in the mornings could that b the reason for it?
But only at first time staring in the day or after a long time been stoped
What oil is recommended for 2001 Mitsubishi galant v6 3.0 it has 170500 miles. I've been using Castrol high mileage 20-50 am I using the wrong oil.
no
20w-50 would be fine for an engine with that mileage on it
if the ambient temp drops to consistently close to 0 c a change back to 15w 30 would be a better viscosity oil
Dec 19, 2017 | Mitsubishi Cars & Trucks
What sort of oil does my CCM604RS need ?
10W40 is standard. 5W40 is o.k. too. You can change the type but mixing different types is forbidden for some reason.
One figure is for fluidity and the other one for temperature rating in extreme conditions. Ask a mechanic.
Aug 16, 2014 | 2001 CCM 604 RS Roadster
Aveo 09 started idling at 800rpm on first startup after oil change, usually 1000rpm at startup
Not likely. 20W-50 is usually used in high rpm engines in warm to hot climate. By any chance is your windshield defroster on? When the defroster is blowing your air conditioner compressor is engaged which pulls the moisture out of the air so you get HOT DRY air blowing on the interior of your windshield
Feb 19, 2014 | Chevrolet Aveo Cars & Trucks
Loud exhaust
Hi
Loud noise from Exhaust means your exhaust system is leaking.
this will make the performance poor on your vehicle.
Get that check and replaced.
Jul 31, 2017 | 2003 Toyota Corolla
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
Jan 26, 2011 | 2001 Audi A4
Just looking for the right oil weight ie: 10w30 or 10w40 or 20w50 Live in Florida for my 2003 Honda Valkyrie Standard
FLORIDA , ME 2 .. I USE A HEAVY OIL IN ALL MY STUFF TILL THE TEMP GOES DOWN OUTSIDE .. I ALWAYS USED CASTOL 20/50 IN MY BIKES OR MOBILE ONE IN MY VETTE 15/50 ..IF'N I WAS ANY HELP AT ALL PLEASE VOTE.. JAY
May 25, 2010 | 2003 Honda F6 C Valkyrie
What happens when i mix 10w-30 with 20w-50 in the
You mixed two different oil weights (BIG NO NO) GOOD luck on the prognosis
Nov 04, 2009 | 1996 Mercury Mystique
What oil do i need for my 1997 deville
alway use a good quality oil & dont mix brands!
20w - 50
Jul 19, 2009 | 1997 Cadillac DeVille
2001 Audi A6 2.7T I was driving on the hwy, accelerated to pass a car, minutes later the oil warning light came on. The oil temp climbed from 220 to 240. A rapid ticking began to emanated from the engine....
VERY POSSIBLE THAT IT IS ONE OF THE TURBOS THAT IS GOING OUT. WILL HAPPEN IF POOR OIL SERVICE. ALSO CHANGE YOUR OIL WITH A SLIGHTLY THICKER OIL IF OVER 80,000. I OWN A 01 2.7T WITH 89,000 AND USE ROYAL PURPLE SYNTHETIC 20W-50
Mar 09, 2009 | 2001 Audi A6
Use of recommended oil viscosity (5w-20)
I ask that same question about my 2007 and was told that the main reason for the lite oil weight was to give better gas mileage. Still though I never changed because I got over tinkering with the manufactures specs. in my hot rod days. Stay with the 5-20W.
Jan 29, 2009 | 2007 Ford Escape Hybrid FWD
Skate Out Loud Laser Hard Nose Skate Plate Complete Logo
384 people viewed this question
Top Skate Out Loud Sport & Outdoor - Others Experts
Bill Eager
Are you a Skate Out Loud Sport and Outdoor - Other Expert? Answer questions, earn points and help others
