Question about Twinhead DURABOOK D14RY
Durabook power jack
Power jack pin
    Sergeant:
  • Twinhead Expert
  • 237 Answers
What about it?
Posted on Nov 03, 2017
Power in center pin hp g62
What is the center pin??
Would you by chance be talking about the DC Power Jack where the Power Cord plugs into the laptop? If so, then see the steps below if your laptop is not booting and you think the DC Jack is your problem.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 16, 2012 | HEWLETT-PACKARD HP G62 Notebook
Have upgraded to windows 7 from XP. no probelms on booting as the max ram for the durabook twinhead is 3G. when it goes to sleep and recover it shows blue screen. Possible causes for this?
I found this issue in some laptops. We have 2 options which i used in laptops and its working fine.
1. Increase the Virtual memory of the laptop. You can do this through my tips posted in Fixya. Click here.
2. You need to change the minimum processor power management from the Power options.
To do this go to Power options in control panel.
Click on the Change plan settings.
Click on the change advanced power settings.
In Processor power management - Click on minimum processor state.
chang it from 5% to 100% - Click apply and OK.
Restart the laptop.
Apr 02, 2012 | Twinhead DURABOOK D14RY
How do i enable my wi fi on my durabook laptop
Make sure you pressed the wireless button. On my durabook it is located to the right of the power button. It should turn green. You can check you network status to see if you are connected, or what wireless networks near you are available. Secured networks need a key.
Apr 04, 2011 | Intel Durabook V38263 Notebook
Hello - i need the master code for durabook notebooks because i forgot my password and cant enter the bios setup please help
In order to reset the Master BIOS password on a durabook, you need to remove the CMOS battery and leave it out for a period of time. This will reset everything and allow you to enter the BIOS screen again.
You can find the User Manual for the durabook here http://www.durabook.com/download/manuals/N1400_ALL_US.pdf
Hope this helps.
Feb 18, 2011 | Computers & Internet
How to replace D620 power jack? pwer jack is "loose" causing intermittent connection with power supply. the problem is "not" power cord.
The power jack is located on the motherboard. It is soldered to it. You have to remove the screws behind the laptop securing the back cover and disconnect the hard drive and GPU cables remove the keyboard so that you can pull out the motherboard. This is necessary since the solder joints are located under the motherboard and the jack is over it. There are 3 pins that are soldered. Remove the solder on all 3 and pull out the jack. Insert the pins of the new jack in the space vacated by the old pins and use a low diameter solder(2mm or less if available and lead free solder only) to solder the pins to the board and voila!
May 18, 2010 | eMachines eMD620-5133 Notebook
My laptop crashed, no sound drive and will not connect to interne
Hi
Issue can be resolved easily, First of all you need complete the driver installation, You can download all the drivers from http://www.durabook.com/drivers.jsp make sure about your exact model so you will get correct drivers. Install them one by one. Also please follow the manual as instructions given very clearly. Here is the link for the manual http://www.durabook.com/manuals.jsp
Let us know if you need further assistance.
Good Luck
Apr 05, 2009 | Microsoft Windows XP Professional for PC
Gateway MX6453 power pin problem
http://shop.ebay.com/items/?_nkw=Gateway+MX6453+dc+power+jack
Any of those should be fine.
Mar 24, 2009 | Gateway MX6453 Notebook
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Durabook s13y
Did you try to download all of the updates that are available? You might need to go to the company web site and see if there is a BIOS Flash for your notebook. Vista has a lot of problems that Microsoft can't even explain.
May 31, 2008 | Twinhead Computers & Internet
Twinhead DURABOOK D14RY Logo
22 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Lee Durbin
Lee Durbin
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
