Question about Samsung 6350 Series UN55F6350 55" LED Smart TV 1920x1080, 240 Hz, HDTV
Won't connect to wifi
We have Comcast and put in all the info we have and still no Smart TV
How do you get Netflix when you have direct tv and Comcast internet
1. If you have "Smart TV", check applications. Most likely Netflix is over there (you have to connect your TV to the Internet either over WiFi or by network cable).
2. If you have TV with no "Internet capability", get any "media player". Cromcast... AppleTV... Media PC...
Sep 26, 2017 | Internet Computers & Internet
I have an old tv with comcast cable. I want to switch to a smart tv that has only been used with netflix. how do i connect smart tv to my comcast cable
Adding a smart tv just requires adding an ethernet cable to your internet connection to the ethernet port on the set. The smart services on the set us a broadband internet connection to work.
Jun 18, 2016 | Vizio 42 in. LCD TV
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
We are paying for netflix. How do we get it on our television? Our television is connected to comcast and we have wifi?
But is your TV a "Smart TV"? That means does the TV connect to the internet. Just because you have Comcast connected to your TV doesn't mean it is getting an internet signal. The black coax to the TV only carries a TV signal.
To get internet service to your TV first you have to determine if it is capable. If it does have a wireless receiver in it, you will have to configure it to attach to your wireless base station. If it doesn't have a wireless adapter you will have to connect a network cable from the base station into the TV and then configure it to work with your network. Once you have that internet signal working on your TV you will be able to use Netflix on your TV.
Mar 01, 2015 | Netflix
Do I need cable hook to make my WIFI to work
If your TV supports WIFI (like a smart TV) and you have WIFI in your house, you shouldn't need any cable. Need to follow the manual of the TV to connect to the wifi and you'll be all set.
Jan 16, 2015 | Televison & Video
How do I get help trying to find out if my phone is acting up or if its Comcast connection
If it's a smart phone. Go to settings and turn off wifi..... if it doesn't work.... it's your Comcast connection
Dec 11, 2014 | Lands Phones
What is smart tv ?
A smart TV is a TV that has more then just basic connections for DVD or TV provider. A smart TV has built in applications that use your WIFI to connect to the internet. Most smart T'S have applications that can provide movies, Web searches and or music channels. Smart TV is kind of like mixing your TV with your PC. Just more basic then your PC.
You must have WIFI in your home to use the features.
Aug 21, 2014 | Televison & Video
I need to find my password to my wifi internet
The Xfinity Arris 805 and 862 and CP3939 wifi info is on the bottom of the router on the white sticker. If the sticker is missing call Comcast 1-800-226-2278
Jan 22, 2014 | Comcast XFINITY
I was given Netflix (stream-in) for a gift, but can not get it to come onto our tv. Please help.
Your TV must be a 'smart' TV i.e. it should have software enabling it to connect to the internet and access features such as Netflix. If you don't have a 'smart' TV then you can purchase a set top box which can be connected to your TV and will allow you to access on-line services such as Netflix. If you have a 'smart' TV then you still need to connect it to your internet router, either with an Ethernet cable or via WiFi if the TV has WiFi built in (or you can buy a WiFi adapter for the TV). If you connect with an Ethernet cable then the TV will connect to your router (and internet) with no further setup. If you use WiFi then you will need to access the WiFi settings menu on the TV and configure the settings for your router.
Jan 19, 2014 | Computers & Internet
Samsung 6350 Series UN55F6350 55" LED Smart TV 1920x1080, 240 Hz, HDTV Logo
Jerry Greenberg
Jerry Greenberg
