Question about Micromark England Table Top Beverage Cooler
Part identification and replacement
I need to replace a part on my England beer chiller, model: MM60002eng, but I do not know what this part is called or what its function is, so I am hoping someone might be able to enlighten me and let me know where I can purchase this part?
The part contains the number PP220MC0R0403 and is pushed on/attached to the compressor. Within its small plastic housing, is a wheel possibly made of ceramic and for which I assume spins at a fast rate. Two wires are attached to this unit and the whole thing is enclosed in a black plastic housing, which is secured to the compressor by one screw.
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Why is there water in the chiller drawer on a French Door Refrigerator-Samsung?
We call that condensation from the moist vegetables, etc. in the chiller, natural occurrence.
Aug 21, 2014 | Samsung RF265AA Bottom Freezer French Door...
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
What is a beer shandy?
A shandy is a beer mixed with juice or soda. This concoction originated in England where they were traditionally mixed with lemonade. Americans adopted this idea and started mixing their beer with sprite
Feb 03, 2013 | Wine & Spirits
Does the type of glass you use for draught beer matter in regards to the style of beer?
According to beer manufacturers, yes. This is especially true for wheat beers. Most wheat beer glasses are specifically designed to tall to help trap yeast sediment at the bottom of the glass so that it does not blend with the rest of the beer while you are drinking it.
The beer froze in the chiller what could be the problem
The thermostat is stuck in the closed position if you noticed that the unit runs and runs and runs without cycling off sometimes. If it cycles, move the thermostat setting up in number (warmer). Make sure, if the unit is in your garage or otherwise not inside where it is warm, that the temp of the outside air isn't below freezing - coolers don't do warming and will not protect the beer from frigid atmospheric temps. Good luck.
Apr 20, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Have an avanti refrigerator model #FF82. and the door to the chiller room, which is under the freezer, needs to be replaced. How do I go about replacing this door?
Hi, I have an Avanti refrigerator model FF82 and there are no shelves inside. Are there spare parts available. There is only a chiller room and 1 bin on the bottom. Thanks
Apr 26, 2008 | Refrigerators
Micromark England Table Top Beverage Cooler Logo
54 people viewed this question
Top Micromark Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a Micromark Refrigerator Expert? Answer questions, earn points and help others
