Question about Panasonic CFH1 ATM/1.86 10.4TCH 1GB-80GB CAM WLS WXPTAB-WV Tablet PC
Dark screen brightness
Buying a tablet in China. Can I change to Swedish language ?
Language changes are made under 'Settings'
When you buy the tab you can ask the assistant to set the language for you
Check out the manual
Lenovo TAB A10 70 User Manual
Sep 01, 2015 | Lenovo A10-70 TAB 8121/1.3 4C 10TCH 1GB...
Screen goes dim on start up ant i have to brighten it every time i startup
change under the control panel the POWER OPTIONS and set it up as you like and save on APPLY.
When you reboot is coming out bright
Mar 10, 2015 | Lenovo A10-70 TAB 8121/1.3 4C 10TCH 1GB...
How do I turn the keyboard sounds off on a Lenovo TAB A10-70?
Go to settings and find sounds and then select the one that says keyboard sounds on or off.
Feb 18, 2015 | Lenovo A10-70 TAB 8121/1.3 4C 10TCH 1GB...
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
Hp tablet compaq tc4200.The screen is very dark cannot adjust brightness in control panel.
if you have the quick buttons software installed disable the ambient light :)
Nov 12, 2010 | Compaq tc4200 Tablet PC
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
May 16, 2010 | Gateway M280E
Only can see partial screen not bright enough on ST5112 model
More than likely it is a bad inverter board, I've worked on lots of these units and the majority of the issue with the dark screen is the inverter board.
Nov 06, 2009 | Fujitsu Stylistic ST5112 Tablet PC
Panasonic CFH1 ATM/1.86 10.4TCH 1GB-80GB CAM WLS WXPTAB-WV  Tablet PC Logo
13 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
