Question about Samsung Washing Machines
Fault code ie
Wont start keeps flashing ie
Fi code flashs 3 times...won't start
The three flashes indicate a fault code,are they three long or short flashes? A long flash is a ten and short is a one,so for instance if you have one long flash and two short ones that is fault code 12 if it was three short flashes that would be 3 ect... You will have to Google the fault code numbers to see what they mean ,ie fault code 21 could be oxygen sensor fault.
Sep 17, 2017 | Motorcycles
2004 corsa c auto wont start when warm fault codes u2103 u2104 u2105 u2107
i have a meriva and battery light comes on and spedometer drops to zero then flickers i have changed alternator and still same problem sometimes car wont start fault codes are u2105 u2103 b1484 u2104 i have been told i need repair done on ecu
Nov 20, 2013 | Vauxhall Cars & Trucks
My bosch clasixx wont start fills and drains ok but just clicks
Possible motor brushes, worst case scenario..motor fault. Put the dial to off, hold the start button whilst turning selector one click left to 30 easy care, turn the dial to 40 cotton (without going thru the off ie all the way round anti clockwise) press start. This will activate the motor test, if you get two lights flashing separated by a led that is off this is a motor fault. (Not necessarily the motor complete, also will indicate loss of contact in the brushes). If it is a model with a display it may show F05. Happy hunting.
Nov 21, 2011 | Bosch Washing Machines
Hello..i repalce the computer in my 1997 sebring convertable because it had problems it would not start..engine wont turn over..and even after i replace the distributor cap,spark plugs & wires and...
You will need to extract the fault codes from your vehicle's computer, as follows:
1) Turn ignition key: ON, OFF, ON OFF, ON (leave in ON position)
2) The Check Engine light (CEL) should start flashing
3) Read codes as follows:
- First group of flashes indicate 1st digit of code (followed by short pause)
- Second group of flashes indicate the 2nd digit of code (followed by short pause)
Note: a long pause separates each fault code, then codes will repeat again
e.g. Flash, Flash (short pause), Flash (long pause)...... indicates Code: 21
4) Code 55 indicates end of CEL code output
Post your codes results here and I can assist you with the appropriate repair.
Cheers,
"If this has helped you resolve your problem, please be kind enough to leave a testimonial"
Jun 10, 2011 | 1997 Chrysler Sebring
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Washer dryer
HI IT ALL DEPENDS ON WHICH LIGHTS ARE FLASHING AS DIFFERENT LIGHTS ARE DIFFERENT FAULT CODES I HAVE A FAULT CODE LIST BUT UNFORTUNATLEY ITS AT WORK & IM NOT BACK IN TILL FRI SO IF YOU CAN HANG FIRE TILL THEN I MIGHT BE ABLE TO HELP YOU OUT
Jul 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
94 honda d4 flashes and wont start
Hi
Its flashing a transmission related fault code. Count the flashes before and after the pause and it will give you the fault code.
Post it on here as a comment and we'll tell you what it means.
If it flashes a 1 and then an 8 then you need to renew the main relay.
Regards
Geordie
Jun 21, 2008 | 1994 Honda Accord
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Washing Machines Logo
10 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
