Question about Dash Designs Premium Slow Squeeze Juicer - JB250SS
Dash juicer Need manual
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
I need a manual, please.
The manuals for the Power Juicers are available here: http://www.powerjuicer.com/power-juicer-manuals.php . Select your model and click on the picture to get the PDF of the manual.
The direct link to the English version of the manual for the Power Juicer Classic is http://www.powerjuicer.com/pdf/classic.pdf .
I hope this helps.
Jun 01, 2011 | Jack Lalanne Power Juicer 250 Watts
Need the operating manual for jack lalanne power juicer express
Manuals for the Jack LaLanne Power Juicers can be found here:
You might take time to browse the site, you will find How To videos, Tips and recipes.
Oct 24, 2010 | Kitchen and Much More Power Juicer
Need a manual for acme juicer 6001, juicer at least 30 years old
The juicer hasn't really changed over time, but you
need to be a little mechanically inclined to adjust
and keep it running properly. Call Waring at tel
1 800 492 7464. Good luck. Mine is 21 years
old and running like new.
Jul 30, 2010 | Acme 5001 Supreme Juicerator Juice...
I have purchased a used Jack Lalane juicer from a friend and
have purchased a used juicer from a friend and she did not have the manual and I need to know how to use it
Oct 04, 2009 | Jack Lalanne Power Juicer 250 Watts
Need Power Juicer manual
Call 1.800.526.2518 or visit www.jackspowerjuicer.com Maybe they'll send you a new copy of the manual.
Jun 24, 2008 | Jack Lalanne Power Juicer 250 Watts
Dash Designs Premium Slow Squeeze Juicer - JB250SS Logo
23 people viewed this question
Top Dash Designs Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Dash Designs Juicer Expert? Answer questions, earn points and help others
