Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Moisture on refrig walls and water accumilation in bottom of area
Moisture on refrig walls and water accumilation in bottom section of refrig. Is there a drain,and does this model have moisture control?
Roper mod RT188kxjw
    Genius:
  • 1,341 Answers
I am pretty sure it is a problem with a block drain..Check that first before you proceed any further.I hope this helps.
Posted on Jun 16, 2009
Refrigator icing at bottom then leaking
bad door seals causing condensation and water accumilates in fridge
Aug 25, 2014 | Whirlpool Refrigerators
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
My water wont dipense. I just replaced the valve. The water run out of the hose where it connects to the fridge when I press the lever but wont come out the dispensesr. Is the waterline in the door frozen...
use a hair dryer and heat up the area around dispenser and around the hole were the ice comes out on the door,or turn the freezer setting down say from 4 to 3 and after a couple of days it should be fine
Dec 05, 2009 | GE HSM25GFTSA Side by Side Refrigerator
The water dispensor line clogged.
you will need to replace the line from the back to the dispensor
Nov 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water on floor of refrigator. Our refrigator is a Frigidaire Crown series model no. F44Q18CC. We have never had the ice maker hooked up sence we owned our refrigator.We bought it about 5 years ago. Lately...
Water collects INSIDE the refrigerator ? It is coming from the freezer. You have a plugged up defrost drain - look for a drain cup inside your refrigerator section agains the wall, this leads to a plastic tube that connects through the back wall of your refrigerator down a drain tube - see if you can remove this and with an object pass it through the drain tube to dislodge anything obstructing the water passage - if you do not have a drain cup in refrigerator then look in your freezer behind the panel you should see a drain hole below the evap fan, where the ice melts and drains through the tube - if this area is iced up or blocked water will overflow to your refrigerator through the cooling vents :)
Sep 18, 2009 | Frigidaire Refrigerators
Water laeks into the refrigerator part of refrig from the freezer above. pan at bottom of refrig is dry. I think drain is blocked. how do i solve this for a whirpool model et18nkxjw00
you are probably right. the drain is located behind the back wall of the freezer section, under the evaporator coil. simplest fix is to remove the rear panel and unplug the fridge,prop the doors open and let it melt on its own, a hair dryer or hot water may speed up the process.
Jun 11, 2009 | Whirlpool GD2SHGX Refrigerator
Water and ice slowly disapeared
When your refrig. is operating , The cool air is dehydrating the surrounding area inside. You will find if you leave a ice tray with water in the freezer for a month. There will be nothing left. This moisture ends up in drip tray on bottom refrigerator . Which evaporates into air outside the refrig..
May 13, 2009 | Whirlpool GS6NBEXR Side by Side...
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
85 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
