Question about Kenmore Oasis HE 27082 Top Load Washer
CODE FOR OPEL CORSA
LOST CODE OF OPEL CORS 1.8
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
Feb 26, 2015 | Opel Corsa Cars & Trucks
Need radio code for opel corsa factory radio
The radio code comes with the car and is unique to the unit itself. You can either go to a dealer and ask him to find out what the code is from the records kept by the manufacturer, or contact Opel direct, or employ an expert to decode the unit for you
May 29, 2014 | 2010 Opel Corsa 1.0
Lost code for Opel Corsa Radio
I would visit a mechanic who knows Opels or call one and see what they say.
Oct 14, 2013 | Rolling Code Scrambler
Cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
Fuse box for vauxhall corsa 1.4 S reg
Opel/ Vauxhall Corsa D fuse box diagram and descroption
Version 1
http://www.autogenius.info/en/vauxhall-corsa-d-fuse-box/
Version 2
http://www.autogenius.info/en/vauxhall-corsa-d-2009-fuse-box/
Feb 12, 2012 | Opel Corsa Cars & Trucks
Kenmore Oasis HE 27082 Top Load Washer Logo
13 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
