Question about Stoves Ovens
Scholtes stove can`t turn it off
I'm asking about a cooker NOT a refrigerator!!
Good Morning Clare:
Now that we know,
Here's a link that may help you.
http://www.scholtes.com/_pdf/booklets/04/10/19508203300_UK.pdf
cheers.
Jun 17, 2016 | Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Scholtes FE46. We have no timer lights but do have temp and function lights. The oven won't unlock. Please help!
try rebooting; unplug or switch off the circuit breaker for 90 seconds
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
I have a scholtes 336 oven and it is locked!!! Help! Please!
Go on line with Schloss Ovens and request technical assistance giving your model number. I do not believe that there is any lock, per say, but something is jammed in the door that is holding it or it has a magnetic safety lock on the door that could be deactivated if you ynplug the unit...Good Luck!
Dec 28, 2012 | Ovens
We have a scholtes oven, we are in france, we don't know the model, child lock is on and we can't unlock it/open door
we had the same problem just now and we solved it.
Our model is a "Fi 466 S" that has three knobs.
Just push all of them at once, which makes the "loughing lock"-display go away. And then press just the middle one for a time. That unlocks the oven.
Hope to be of help.
Oct 14, 2010 | Ovens
My stove works but it wont stop beeping
My scholtes cook top tig 664 won't stop beeping... Coming close to using a hammer! Help!
Oct 04, 2010 | Kenmore Ovens
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
10 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
