Question about Amana Radarange Microwave Oven
Amana rs 560 does not start
Assume it is the start buttom
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
HOW TO REMOVE A MICROWAVE
I assume you are talking about an "over the range" microwave.There should be 2-3 bolts holding it in from the cabinet above.You probably should have a second person to help.Remove the bolts while holding it up,when the last bolt is removed,lower the front,then lift the rear of the microwave to release it from the wall bracket.
Jul 06, 2012 | Amana Microwave Ovens
My menumaster UC11E2 continually shows "cln fltr"
The filter is on the buttom of the front door. take it out and wash it. Just look under the door.
Apr 10, 2011 | Microwave Ovens
What dont is mean error 5 model rf17 and the electronic swicht dont work 1 and 2 6 buttom swicht
The service manual for models RCS10 and RFS12 is here for you to download.
The service manual for model RFS18 is here.
There is also a technical sheet inside the oven, usually located hidden on the left side near the bottom floor of the oven.
The sheet should tell you what the code means.
You can probably find exploded views and order parts by model number here.
Let me know if I can help further.
Aug 21, 2010 | Amana RFS18MPS Microwave Oven
The start & stop buttoms are not working , the oven powerline is showing on and the temparature regulator is working but the start & stop buttoms are not operating.
The buttons are not working due to the fact the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
Mar 13, 2010 | Microwave Ovens
Amana Model MVH210E The unit turns on and starts up normally but it does not heat and seems to make an increased vibrating noise
I'm having the same problem. When I hit start, the light and fan comes on but no heat. There is not a turntable in the MVH210E model. Any ideas how to fix it?
Jun 06, 2009 | Amana AMV4204A Microwave Oven
Start buttom doesn't work
Okay, it does sound like your membrane keypad is worn out at the Start pad.
It may be available separately as a key sheet or already attached to a new plastic frame.
In case it comes as a key sheet and if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
LG's Latin American Wen sites are here.
Dec 16, 2008 | LG LRM1250 Microwave Oven
I want to see the clock on my microwave amana rcs820bl
Set the clock?
Normally one of these combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please write back if you need further help.
Sep 07, 2008 | Amana Microwave Ovens
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Amana Radarange Microwave Oven Logo
52 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
