Question about CoinMate Coin Sorting Machine - COIN SORTER
Coinmate machine displays jammed
Display shows jammed. How to up jam it?
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
Display shows paper jam, but no paper in machine.
Hi
Turn it off and on.
Try disconnecting the printer from power and from the PC.
Leave it as such for a while before connecting again.
Feb 28, 2012 | Brother MFC-5440CN All-In-One InkJet...
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    My printer keeps showing the message, " paper jam
    Hello Tessty,
    The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
    Please visit the link provided below to resolve the issue step by step :
    http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
    Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
    DISPLAY SHOWS "PAPER JAMMED "READING
    I think it still have maybe a very small paper jammed.
    Tries dismount the more you can from printer, since I'm almost sure it stills remains maybe a very small paper...
    Apr 14, 2011 | Canon PIXMA MX300 All-in-One Printer
    Paper Jam and showing J42 on screen
    look to d LCD display lay out of machines shows and the location mo paper jammed, release all green lever ang slowly removed the jam paper.
    Aug 10, 2009 | Panasonic DP-8045 Grayscale Copier
    Ricoh MP 5000, says it has a paper jam, but I can't phyicial see a jam, wont print, scan, copy, or fax
    if the jam still shows when you turn the machine off and on then you will have to look first to see which tray you were using at the time take the tray out and look inside the frame to see if paper has stuck by the feed rollers then open the side paper path guide to check non is on teh way up from there the next is reg transfer and fuser sections also pull the duplex out to make sure its not under the travel plateand last is to check betweent ehfuser exit and finisher opent he dooor on finisher if you have one and lift the plate at top right had the paper can sometimes be hidden there... failing that the sensor for the paper exit from fuser to duplex can sometimes jam a small bit there...if you know how to get into the sp modes you can go to data log 1 there you have the jam counters and jam history look at latest and the area will show up where it could be last. good luck A..
    Jun 26, 2009 | Ricoh 4506 Copier
    Display showing Remove orig from ADF
    Remove original from auto document feeder... it thinks that there is a paper jam... check into that.
    Jun 05, 2009 | Canon FAX L-120 Plain Paper Laser
    Scanner Display Shows False Jam
    You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
    PLEASE don't forget to RATE ME (FIXYA) for my help..........
    Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
    CoinMate Coin Sorting Machine - COIN SORTER Logo
    88 people viewed this question
    Top CoinMate Retail Supplies Experts
    Electroboy
    Electroboy
    Patrick Tinashe...
    Are you a CoinMate Retail Supply Expert? Answer questions, earn points and help others
