Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Change batteries in weiser Powerbolt elec deadbolt
How to open to change batteries.
    Scholar:
  • 101 Answers
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Posted on May 24, 2014
SOURCE: Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
Posted on Jun 11, 2009
  • 26 Answers
SOURCE: my powerbolt keeps beeping short beeps and then
dead batteries
Posted on Aug 18, 2009
SOURCE: i have an old weiser powerbolt 3000 with a remote.
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
Posted on Jan 24, 2010
  • 5160 Answers
SOURCE: PIN NUMBER
Take off the cover on the inside door of the lock. Grip it on the sides and pull up or twist. Press the Program button (on the left of the power board) once. Then type in desired code (4-8 digits) on the Touchpad followed by pressing the Lock button. If you hear a 2-second beep, the code is properly stored. If you don't hear the beep, the encoding period timed out. Then you need to repeat the sequence from pressing the Program button but do it faster. To store a second code, press the Program button twice and then type in the desired code followed by the Lock button. (Any earlier code will be lost during these steps.) Then replace the cover over the power board.
If you want to print out the programming information, go here: http://www.weiserlock.com/en/products/smartseries/powerbolt.aspx and scroll down to the Installation instructions. The programming instructions are at Step 5 on the PDF.
I hope this helps.
Posted on Jul 23, 2010
sonicboomele
  • 1557 Answers
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Change the batteries in my hand held can opener modelS1212
Put both thumbs in the center of the flat side (the bottom). Apply downward pressure and move your thumbs toward the "tail" of the can opener to slide the bottom off and reveal the battery compartment.
Sep 23, 2014 | Kitchen Appliances - Others
Can't open to change battery
Google the model number for "manual" which if found will have instructions for replacing the battery or take it to some place like walmart who will open and replace it for you.
Nov 05, 2012 | Watches
I HAVE A SURESAFE20ES; BATTERY IS DEAD; WHERE DO I OPEN TO CHANGE THE BATTERY? IT'S PRETTY URGENT
You need to charge the battery...not change it. If you can get a charge into it try a factory default code like 7777 to try to reprogram the safe.
Jul 04, 2012 | Cars & Trucks
Change battery
please specify remote model for possible solution
May 17, 2012 | Dryers
Hello, Ineed to change the battery of the time and date. I want hnow the number of the battery to buy one and changing. Regards Josephine.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
Sep 13, 2009 | Compaq Presario Notebook
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Changing the batteries
I'll give you info on how to change batteries in two different type mouse units. Not sure what type you have.
The normal way to change batteries on a mouse is to turn it over and open the little door on the bottom The compartment holds 2 AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 16, 2008 | Logitech 931150 Mouse
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
414 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
