posted by angiesings on Oct 31, 2007
what do I do if the power to my mackie board turned off while the amp was still running and it created a large thump and now my sx1800 protect and peak light are on and won't go off? Please help!
Solution #1
posted on Nov 03, 2007
Hi There,
Manufacturers install protection devices in their audio systems that are there for that purpose, any loud 'thump' or 'crack' trips the protection device so the loud speaker wont be burnt out. Speakers are expensive so the manufacturer does his best to allow you to listen to very loud sound and yet provided protection in case you exceed the sound rating of the output protection device.
In your case it sounds like the protection device has done its job but has not reset, to allow more listening...
Check the operational manual that came with the amp system to see if there are re-set instructions available to you....
If you dont have the reset detail, then phone/e-mail the manufacturer to obtain the reset information...
If there is no resetting you can do as a consumer then it should be no problem for a service shop to do the reset for you...
It may be a simple internal fuse that has blown but if its not accessible from the outside then I dont suggest you go inside and make changes unless you are skilled and trained in electronic servicing...
Cheers for now YUBEUT
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Samson SX1200 Amplifier
Email this problem
Email this problem
Can you Help with these Amplifiers and Preamps problems?
remote codes for sansui audio...
I have an older sansui stereo... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
