Problems with Beckett 76002N1S05U AquaSmart 2N1 Sensor
Error message
Out of balance message being received constantly even after redistributing the load - knocking
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Dec 14, 2014 | Fisher and Paykel Aquasmart wl80t65c
Aquasmart top loader, has message i have no cold water
Tub water level sensor tube is off off tub or level sensor is bad check to see if still under warranty or recall
Aug 26, 2014 | Washing Machines
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Why has our washer stopped working through a cycle and why wont it turn on again
The most common problem with AquaSmart is the pump.
The pump has gone bad and blown the motor controller board.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
May 18, 2014 | Fisher and Paykel Aquasmart wl80t65c
Flickering oil light and oil pressure sensor message
Check the filters, this normally causes this problem.
Apr 06, 2014 | Beckett Pump Oil Burner
Wl80t65c 130 fault
Rotor position sensor Error .. Sensor is not send correct signal to control.
1)Sensor could be bad
2) wire from sensor broken
3) control board bad.
Jun 13, 2013 | Washing Machines
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
jasbo
jasbo
