Question about Northstar Pressure Washer Turbo Nozzle
Water leak northstar power washer m1578111c when water supply is turned on water runs out the chemical inlet
  • 365 Answers
Bypass valve is shot or stuck in the "open" position
Posted on Jun 15, 2009
What is causing water to leak out of the resovior when the power washer is running?
I am assuming you mean the chemical resovoir tank? If water is running out of it then water is coming back up your chemical injector. This usually means at some point the ball and spring in your injector got stuck...typically people take them apart at the nipple to ry and fix it. not realizing there is a small ball and spring in that nipple. This is actually a ball valve to prevent water from coming out of the chemical injector nipple. Replace the ball and spring if needed as well as the oring seat in the nipple. This will stop your tank from filling up. Good luck
Sep 06, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Troy bilt 2600 psi when you turn the water on it shoots out through the chemical supply inlet
My chemical supply inlet has a checkball and a spring that keeps pressure in check. There must be debris behind checkball. Easy to check by removing the fitting. If faulty and parts not available, plug fitting and add an aftermarket injector from www.pwmall.com. that you can install when you need it. Good luck
Sep 30, 2011 | Honda Black Max 2600 PSI Pressure Washer
Will not build presure at pump just like a garden hose
run some oil in inlet/outlet/or/oil then connect hoses back what is going on is when you run it then store it the seals dry up keep it oiled when storing.
Jan 15, 2011 | Northstar Gas Powered Wet Steam & Hot...
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
The water supply to my pump was disconnected while
Yes the impeller is probably shot. If you can find the parts it should be easy enough.
Aug 02, 2009 | Northstar Garden
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Water coming out of washer
Depending on the model of the machine, it is most likley a cracked control head or split outlet elbow. Remove the covers and run the machine to locate the source of the leak. Ifit is the control head it will spray water from the top just behind the chemical inlet elbow.
Feb 06, 2009 | Karcher K2.26 Electric Power Washer
Northstar Pressure Washer Turbo Nozzle Logo
128 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
