Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
What is the proper oil gas mix for a tryobilt model tb926B
What is the proper gas to oil ratio?
How do I mix gas + oil for the husqvarna 128 ldx(what's the ratio)
It should be 50 to 1 it would be good to get a ratio rite cup an use it to measure your oil for gas . How ever the saw mix oil should tell you how much gas it makes
Sep 18, 2014 | Husqvarna Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
What reatio of gas to oil? And what kind of oil?
32:1 / 40:1 will be fine.... your choice of pre-mix oil...pick your fav brand . use a ratio-right cup and make it simple
  1. Pump one gallon of gasoline into a gas can. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+3322788282+9016233241+8962074949+8941458308+0371618899+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Measure out the proper amount of two cycle oil in the Ratio Rite.
  3. 3Pour the required amount of oil into the gas can with the gasoline.
  4. 4Shake the container lightly until all of the oil is thoroughly mixed in with the gasoline.
  5. 5Pour the mixture into the machine`s gas tank.
Jan 23, 2010 | 2004 kawasaki KX 125
Mcculloch 310 oil mix ratio
The proper gas/oil ratio is 50:1, that is 50 parts gas, to one part (2) cycle oil.
If you plan on leaving gas in the tank when not being used, I always recommend adding some gas stabilizer, such as Sta-bil, which makes starting the chain saw easier regardless of how long the fuel mix has been sitting in the tank or saw (up to 2 years according to Sta-bil label)
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to mix gas and oil ratio
hello. the mix has not changed over the years. it is important however to use ryobi oil. go to any home depot and get the small bottle of ryobi oil that is enough for just one gallon of gas, use new gas fresh from the pump, and enjoy.
Aug 18, 2009 | Ryobi Factory-Reconditioned ZRDS11008...
Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
Oil
40:1 fuel mix ratio is good for this model. you put gas in the upper tank and 2 stroke oil in lower tank the mix pump will do the mix, if you are not sure the pump is working properly, mix 4 ounces of 2 stroke oil into 1 gallon of gasoline and put the mix in the upper tank, it reach the carburator by gravity
Nov 20, 2008 | 2005 Honda Dio
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
75 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
