Question about Avaya Computers & Internet
Backup memory card Avaya 308
How to code
I have a Avaya Partner phone with the caller id screen and I have caller id on the account. However, the phone will not display incoming numbers. Am I missing something?
Can you please list the cards in the system?
IE: 308 EC, 206 EC ? Should be int the middle of the cards of your phone system.
Oct 01, 2014 | Avaya Lucent Partner 616 Phone
What to do if Backup Failed: Insert Card?
Shut down the system. Remove the Backup/Restore card. Make sure the slot and card are debris free. Re-insert card and re-start system. If Backup fails again, then the card or slot has failed. A quick test is to shut down the system move the Backup card to the other slot and re-start. If Backup works, then bad slot. Otherwise looking at a replacement Backup/Restore card.
Jul 02, 2014 | Avaya Lands Phones
Reset acs 308ec to factory settings
Im assuming you mean an ACS 308 processor not the 308ec expansion module. From a display phone at either extension 10 or 11 press feature 00 - left intercom button twice - #98925327
Apr 28, 2014 | Avaya Partner ACS 308EC (108463001)...
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
Jan 10, 2013 | Avaya Partner ACS 308EC (108463001)...
Lost the charger and usb cable where can I buy them
Apex Battery offers two DXG-308 chargers
http://tinyurl.com/2fstzxp
laptoptraveler.com has a charger they say is compatible with the DXG-308
http://www.laptoptraveller.com/battery-dxg-dxg-308-digital-camera-accessories.html
You can bypass the need for a USB cable with a card reader. That also saves wear on your camera.
Search Amazon.com for "card reader" and choose one compatible with your memory card
Nov 07, 2010 | DXG Technology DXG-308 Digital Camera
Partner ACS turning on and off on it's own
One of the cards is bad in the unit. Assuming you have a 308 processor and 308 ec card and two cards in the system The 308 ec card has a bad or power supply in the card
When this happens look at the cards lights.
This is nothing you can fix yourself without a Avaya technician.
Apr 08, 2010 | Avaya Lucent Partner 616 Phone
Installed ACS R1 in 5 slot carrier with 4 308EC R3 modules. Processor works but non of the 308EC cards work and no lights on modules.
Try powering off, reseat the processor, and both cards. Power on.
If that doesnt work, remove the last 308 card and power up. if still not work, power off and swap the 2 3-8 cards.
Sep 17, 2009 | Avaya Partner ACS 308EC (108463001)...
Remotely program my avaya 8
You will need a remote access/backup restore card (silver card) Then you will need the remote admin software available for free at Avaya.com
Aug 16, 2009 | Avaya Corded Phone avaparp18d
Replacing Partner 308 w/ 509&400EC
You don't need the 400 module for the voicemail. Therefore, you also don't need the 2 slot carrier either.
Feb 27, 2009 | Avaya PARTNER RELEASE 7 RAC-REM ACCESS...
Computers & Internet Logo
81 people viewed this question
Top Avaya Computers & Internet Experts
David Payne
David Payne
PhantomLib
Level 1 Expert
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
