Question about GN Netcom GN 9350 Wireless Headset
Caller cannot hear me all plugged in as per manual GN9350
GN9350e - plugged in handset as per manual; hear dial tone and able to connect. However, caller unable to hear me at all.
Is there a mute button on the T7316E norstar phone
Have you tried another handset or especially another handset cord? Those problems are usually poor connections at the small modular connectors for the handset.
Sep 05, 2014 | NorStar T7316E Corded Phone
Hi, I tried to configure my phone in below steps,
Maybe a mute button is on...volume setting all the way down....? Try calling you number from another phone..See if anything lights up. Bent connection pin in phone base.Try another cord. Trying to help.
Aug 11, 2013 | AT&T 5840 5.8GHz...
Jabra GN9350e - my voice echo's back to me but the user hears me fine, is there any way to change the feed back?
Here's what fixed it for me (running Windows 8.1 on a Surface Pro 3):
1. On your taskbar, right click on your volume control options (the little speaker icon), and choose "Recording Devices." ALTERNATIVE: You can also get there from Control Panel, searching for "sound" and selecting "change sound card settings," then go to the "recording" tab.
3. Right click on the GN9350 and select "Properties."
4. Go to the "Listen" tab.
5. Unclick the "Listen to this device" checkbox.
6. Save and exit.
Oct 28, 2010 | Jabra GN9350e Wireless Headset
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
Says Line In Use on display - when outside caller calls, no can hear phone ringing and answering machine does not pick up
plug another known working phone into this jack check for dial tone.if there the check settings and program on handset..
Jan 20, 2010 | General Electric 28821FE2 Phone
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
GN Netcom GN 9350 Wireless Headset Logo
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
