Question about Mitsubishi WD65C9
No picture blinks green then goes to red
    Scholar:
  • 195 Answers
Try a new phillips bulb. DO NOT use a neolux lamp !!
Posted on May 08, 2014
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Mitsubishi 52825 TV has new lamp. Green light goes
Try these first then we will check the internal components
TV needs servicing CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s Solution 1 Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution. 3 When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me
Posted on Jan 27, 2011
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
Mitsubishi WD65C9 Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
